simbey1982 Posted October 26, 2005 Share Posted October 26, 2005 Hey all...im missing a sensor on my new engine, and i need to know what it is Its a 2.5L SOHC model from a 2000 forester. Its all complete exept for this one sensor...here is a description It is a silver metal roundy block that sits kinda in front of the intake manifold, it has two medium sized vacuum tubes going to it and one electrical wire plugs into it....any ideas??? MAP sensor?? not sure Cory Link to comment Share on other sites More sharing options...
nipper Posted October 27, 2005 Share Posted October 27, 2005 its a thingy ... can you post a pic? nipper Link to comment Share on other sites More sharing options...
Legacy777 Posted October 27, 2005 Share Posted October 27, 2005 What is it connected to? Link to comment Share on other sites More sharing options...
simbey1982 Posted October 27, 2005 Author Share Posted October 27, 2005 hmm...let me work on getting a pic...as im doing this all from memory Link to comment Share on other sites More sharing options...
99obw Posted October 27, 2005 Share Posted October 27, 2005 Sounds like the evap purge solenoid. EDIT: or EGR control solenoid if so equipped. Trace the vacuum lines, do they go to the backpressure transducer (flying saucer shaped thingy), or do they go to the metal fuel lines that run below the manifold. I am going from memory of EJ22 and Phase I EJ25, so I may be off. Link to comment Share on other sites More sharing options...
Subie Gal Posted October 27, 2005 Share Posted October 27, 2005 sounds like a map sensor or crank sensor Link to comment Share on other sites More sharing options...
simbey1982 Posted October 27, 2005 Author Share Posted October 27, 2005 Thanks for the input guys....I agree with Jaime about it being the map sensor....i will get a pic and post so i can be sure Link to comment Share on other sites More sharing options...
ferret Posted October 28, 2005 Share Posted October 28, 2005 Sounds like the air assist injector valve, if it is the same as the 01/02. It is controlled by the ECM to allow air to the injectors at low speed to atomize the fuel at a better rate. See if the .pdf below fits your missing sensor: Link to comment Share on other sites More sharing options...
