chrisw Posted October 27, 2005 Share Posted October 27, 2005 Some work was done on my 92 Legacy wagon at the beginning of summer that involved disconnecting the temperature control cable from the heater unit. The cable clamp evidently was not installed correctly, as the cable has come loose. I do have a Haynes manual, but illustration 10.4 doesn't show much detail. The clamp that I have looks very similar to the "Cable clamp" (part #35) in illustration 10.9 of the Haynes manual. I don't believe the attachment point on the heater housing has broken or that the wrong clamp was used (but both are possibilities). Perhaps there is an additional part involved ... I normally can figure this stuff out, but not this time (at least not yet). Can someone provide an explanation on how to do this, or perhaps point me to a better illustration. Thanks ... Link to comment Share on other sites More sharing options...
trxeslr66 Posted October 27, 2005 Share Posted October 27, 2005 I'm not sure how similar they are, I took my 99 legacy heater/ac unit out to replace bulbs and disconnected the cable at that time. I re-installed it myself without any manuals easily. Do you mean the cable is disconnected from the back of the heater/ac unit in the dash? Have you pulled the heater/ac unit out? Link to comment Share on other sites More sharing options...
CarolinaPilot Posted January 17, 2011 Share Posted January 17, 2011 Hey guys-- It is cold out there and the tempature control cable end (portion down in the passenger side foot well) has come off the heater box in our 97 OBW. The end of the cable has an eye and I have slid it back on a white shaft. How do I make it stay on and make sure the cable is adjusted correctly so we can get heat back inside our daily driver. Thanks a million. D3 Link to comment Share on other sites More sharing options...
djmark7 Posted January 17, 2011 Share Posted January 17, 2011 there should be a clip it goes into on the box i believe before the cable comes outta the sheath if you know what i mean Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 17, 2011 Share Posted January 17, 2011 Yes - there should be like a plastic clip that the cable "slots" into IIRC.... Maybe look closely..... broken off? I haven't seen that happen but you never know.... GD Link to comment Share on other sites More sharing options...
94Loyale Posted January 18, 2011 Share Posted January 18, 2011 CarolinaPilot, as already stated, there should be a black clip on the side of the heater box. But if you can't find it, or can't get it connected, it is cold outside! Just move the lever that the cable attaches to until you get hot air, at least until you can look for the clip to hook it up correctly. Link to comment Share on other sites More sharing options...
CarolinaPilot Posted January 18, 2011 Share Posted January 18, 2011 Thanks for the reply and help guys. I got the cable attached and the heater box opening to allow hot air in!!! What I can't figure out is where this 1/2 circle c-clip goes on the cable exactly. What do you think? 94Loyale said: CarolinaPilot, as already stated, there should be a black clip on the side of the heater box. But if you can't find it, or can't get it connected, it is cold outside! Just move the lever that the cable attaches to until you get hot air, at least until you can look for the clip to hook it up correctly. Link to comment Share on other sites More sharing options...
94Loyale Posted January 18, 2011 Share Posted January 18, 2011 Basically, take the cable out of the holder, but leave the hook end attached to the heaterbox lever. Set the temp control knob to hottest. Then move the lever on the heaterbox all the way to full hot. Then just snap the cable into it's holder. Link to comment Share on other sites More sharing options...
