lekmedm Posted October 28, 2005 Share Posted October 28, 2005 I've tried searching for this without any luck. The auto trans shifter light is out in my 1998 Legacy Outback. What kind of bulb is in there? Can I get one from an autoparts store or Radio Shack, or does it have to be OEM? Also, how do I get in there to replace the bulb? Thanks. lekmedm Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted October 28, 2005 Share Posted October 28, 2005 You should be able to find those almost anywhere.I cannot tell you the number offhand but I know someone else here may know.Did you already pull the old bulb? Link to comment Share on other sites More sharing options...
trxeslr66 Posted October 28, 2005 Share Posted October 28, 2005 To take this apart...lift up the lid to the center console, take the 2 screws out. The plastic piece will now lift up and come out from where you take the screws out, down t below the ash tray. It comes out in 2 pieces, the second piece needs to be turned and is slightly more difficult to get out. Then these is another case to remove to expose underneith the shifter plastic. I am not sure where the lights are located but I have had mine apart this far and it is simple. After you see the lights, take them to radio shack or the dealer to find a close match. Link to comment Share on other sites More sharing options...
nipper Posted October 28, 2005 Share Posted October 28, 2005 I've tried searching for this without any luck. The auto trans shifter light is out in my 1998 Legacy Outback. What kind of bulb is in there? Can I get one from an autoparts store or Radio Shack, or does it have to be OEM? Also, how do I get in there to replace the bulb? Thanks. lekmedm Autoparts store. This is a standard automotive light bulb nipper Link to comment Share on other sites More sharing options...
