gillans Posted October 29, 2005 Share Posted October 29, 2005 Can somone tell me how to check for a fault code on a 97 outback EJ25 auto. is this something i can do at home? where can i find a list of what each code means. Thanks in advance. Gillans used to drive a Mitsubishi Canter 4wd now had to downsize. Is that a bad thing?I DON'T THINK SO. Link to comment Share on other sites More sharing options...
Cougar Posted October 30, 2005 Share Posted October 30, 2005 You will need a code reader that uses the ISO 9141 protocol. Here is a link to the unit I purchased. It will handle all the common protocols and the new CAN BUS also. At the link you can type in a error code in the window to find out what the error is. http://www.iequus.com/item.asp?cid=7&pid=3110 Link to comment Share on other sites More sharing options...
gillans Posted October 31, 2005 Author Share Posted October 31, 2005 Thanks mate. Cougar said: You will need a code reader that uses the ISO 9141 protocol. Here is a link to the unit I purchased. It will handle all the common protocols and the new CAN BUS also. At the link you can type in a error code in the window to find out what the error is. http://www.iequus.com/item.asp?cid=7&pid=3110 Link to comment Share on other sites More sharing options...
