Needed ASAP - IAC for 90 legacy wagon 2.2l
I was running some tests on my 90 legacy wagon 2.2l manual trans and found that my IAC is bad.
The car is idling at around 2k @ normal op temp.
pulled the IAC with ign. on , engine off and the plunger is all the way up inside the housing , w/the electrical connectors attached.
If I unplug the IAC with the ign on , engine off , the plunger falls out of the housing.
Also lost the spring that goes inside , GRRRRRRRRRR.
Any help would be great.
Suppose to sell the car tomorrow , but thats probably not gonna happen now.
:banghead:
Also the lead wire has 3 prongs and the IAC only has 2 .
I think its the wrong IAC to begin with?
  oregonloyale said:
Stumpy, thanx for your help.
Ill let ya know here if it works.
Just so yall know , stumpy sold it to me for $25 + $6 via flat rate USPS box.:grin:
Flat rate boxes ship ANYWHERE at ANY wieght for flat rate.
USPS has 3-4 different size boxes that have different flat rates.
Where did you find the $6 flat rate box? My post office only has $7.70 boxes. Could it have been UPS or FedEX?
