brad harvey Posted October 30, 2005 Share Posted October 30, 2005 i am working on a 94 subaru legacy and am a bit perplexed when i slow down fast, for example at a stop light or off of the freeway and the idle drops it doesn't remain constant, it bobbles when it gets below a thousand and sometimes it bobbles so much that the car dies, and a couple of times i haven't been able to get it started after that, i thought it was the idle air control valve but i replaced it and the problem continues, can anyone help? Link to comment Share on other sites More sharing options...
oregonloyale Posted October 30, 2005 Share Posted October 30, 2005 Is it throwing any CEL's? Link to comment Share on other sites More sharing options...
Cougar Posted October 30, 2005 Share Posted October 30, 2005 If the plugs are in good shape I would check the EGR valve and clean it. Link to comment Share on other sites More sharing options...
brad harvey Posted October 31, 2005 Author Share Posted October 31, 2005 If the plugs are in good shape I would check the EGR valve and clean it. plugs are ok, egr too, and no bad cells, i was thinking ecm, but wouldn't that be malfunctioning all the time, not just at idle? Link to comment Share on other sites More sharing options...
Cougar Posted October 31, 2005 Share Posted October 31, 2005 It isn't the ECM. You could try running some Seafoam through the intake and the other half in the fuel tank to see if that helps things. Link to comment Share on other sites More sharing options...
beezer Posted October 31, 2005 Share Posted October 31, 2005 Does the 94 even have an EGR? Thought it was fuel purge solenoid in the earlier cars? Link to comment Share on other sites More sharing options...
Legacy777 Posted October 31, 2005 Share Posted October 31, 2005 No, the 94 does not have an EGR valve. I'd spray some brake cleaner in the IAC valve tube. Also, run some seafoam through the engine. Link to comment Share on other sites More sharing options...
Cougar Posted October 31, 2005 Share Posted October 31, 2005 Thanks for the heads up about the EGR valve fellas. I didn't know that. Link to comment Share on other sites More sharing options...
shortlid Posted October 31, 2005 Share Posted October 31, 2005 Check all vacuum hoses as well. at 11 years old they are going to crack and leak vacuum! Link to comment Share on other sites More sharing options...
oregonloyale Posted October 31, 2005 Share Posted October 31, 2005 Bust out the starting fluid and spray down all the vac hoses while the car is running. If one of them is bad itll drop or raise in idle speed. Link to comment Share on other sites More sharing options...
82bratavenger Posted November 8, 2005 Share Posted November 8, 2005 carb cleaner is a little safer than starting fluid and will be as effective. Just don't use brake cleaner it will make some toxic fumes. You may also check you MAF sensor. My Brother was having a similar problem with his '90 Legacy w/2.2L and that is what I found the problem to be. Just a thought. Link to comment Share on other sites More sharing options...
