Havoc_66 Posted October 31, 2005 Share Posted October 31, 2005 Which way should the fan on the radiator spin? Pushing air out of the car, or pull it in? Link to comment Share on other sites More sharing options...
NoahDL88 Posted October 31, 2005 Share Posted October 31, 2005 it should pull air through the radiator, so when your hand is behind it, between the fan and the engine, it should be blowing on it. Unless, the fan is on the front, then it should push, but you should still feel it on your hand. no matter, either way, the fan should push the air from the front of the car towards the rear. was that too much answer for a simple question? Link to comment Share on other sites More sharing options...
Havoc_66 Posted October 31, 2005 Author Share Posted October 31, 2005 No that was great, thank you!!! Link to comment Share on other sites More sharing options...
Ever Victorious Posted October 31, 2005 Share Posted October 31, 2005 Havoc_66 said: No that was great, thank you!!! Aight, apparently I have + and - mixed up. I'll see about fixing that tomorrow and running the car again to see if that fixes the cooling issue. Link to comment Share on other sites More sharing options...
