Rebello240zx Posted November 1, 2005 Share Posted November 1, 2005 ok I had an attack by gremlins this morning. the wagon is a 92 loyale 4wd d/r 5spd with only 168k on it, just breaking in right? Well I start it up this morning and it billows white smoke out the tailpipe. I mean lots of it! I filled my front yard and my neighbor's in 2 minutes, and then oil pours out of the exhuast ports and starts dripping on the ground! There is oil in the intake system, coming from the pcv i assume. I turn it back on and it smokes but not nearly as bad, but no oil drips (I have one of the few subies that normally dosen't leak) I replaced the pcv valve and it no longer smokes but it wasn't bad in the first place... I am clueless as to what happend to my wagon any thoughts ideas? It does have a functional hood scoop... I wonder if water got in their somehow... i'm in cali so it doesn't get real wet over here, and it didn't smell like coolant or water. I'm stumped.... Link to comment Share on other sites More sharing options...
Subarian Posted November 1, 2005 Share Posted November 1, 2005 White smoke usually means coolant, while blue or blue-gray is oil. Had the car been sitting for a while? Also, you say you have a functional hood scoop. Is your car a turbo or is it an aftermarket scoop? If it's still smoking, what color is the smoke, and what does it smell like? Link to comment Share on other sites More sharing options...
Rebello240zx Posted November 2, 2005 Author Share Posted November 2, 2005 White smoke usually means coolant, while blue or blue-gray is oil. Had the car been sitting for a while? Also, you say you have a functional hood scoop. Is your car a turbo or is it an aftermarket scoop? If it's still smoking, what color is the smoke, and what does it smell like? Car sat for 2 days maybe if that, and it didn't smell like coolant or oil but something else. not sure what though. oil was in the throttle body and it came out of the exhuast ports as well. the hood scope is a homebuilt one so aftermarket i guess. It also stopped smoking, eventually around like 4 pm or so. I just don't get it. dosen't smoke at all today go figure. Link to comment Share on other sites More sharing options...
4WDFrenzy Posted November 2, 2005 Share Posted November 2, 2005 It almost sounds like a leaky valve guide. That is rather strange that it did that. Did you run it hard or anything before it sat? Link to comment Share on other sites More sharing options...
Subarian Posted November 2, 2005 Share Posted November 2, 2005 It sounds like a practical joke a friend of mine played on someone once. I'd just drive it and keep an eye on the oil and coolant levels, and if it doesn't come back, the gremlins have moved on.... Link to comment Share on other sites More sharing options...
Rebello240zx Posted November 4, 2005 Author Share Posted November 4, 2005 It almost sounds like a leaky valve guide. That is rather strange that it did that. Did you run it hard or anything before it sat? Well I don't know what happened or what it was, but it is gone. go figure. And usually I'm nice to it, It hardly sees 4k rpm. I simply don't know what happened to it but I'm watching all gauges real close... :-\ thanx for all the input Link to comment Share on other sites More sharing options...
soobscript Posted November 4, 2005 Share Posted November 4, 2005 Just a note on the PCV... Most of the valves I have seen are fine, but the hose(s) are completely clogged. Which makes the valve about useless. Link to comment Share on other sites More sharing options...
