Loyale 2.7 Turbo Posted December 3, 2012 Share Posted December 3, 2012 ... I cut the round 9004 socket from an old set of broken plastic headlights from an unknown car the junkyard let me have and I dremmel'd the tail light socket bigger and JB welded the 9004 Twist lock socket part to the back of my tail lights. I bought 9004 pigtails from Napa for like a dollar each and wired it up to high only. Stepped up to a bigger fuse and it worked for years. It eventually half melted the reverse section of tail light because it got to hot one night but I got over it. Thank you for your Kind Answer. My Subaru "BumbleBeast" also has Halogens for the Reverse Lights, but I use the Bulb that you can see in the Following Photo... ...marked as "Halogen" ... it came with the 1156 Base already, and the Box said that it also will melt the Plastic if it is Lit for more than three Minutes. Kind Regards. Link to comment Share on other sites More sharing options...
legacywaggin Posted December 12, 2012 Share Posted December 12, 2012 (edited) 98 legacy on outback struts and forester wheels http://imageshack.us/photo/my-images/641/img0024ztj.jpg/ Edited December 12, 2012 by legacywaggin Link to comment Share on other sites More sharing options...
turbosubarubrat Posted December 12, 2012 Share Posted December 12, 2012 my 1983 ea81t wagon Link to comment Share on other sites More sharing options...
cal_look_zero Posted December 12, 2012 Share Posted December 12, 2012 My 1997 OBS. Just shy of 250k on the body. Engine: 1998 EJ25D block Mahle bearings NPR rings Balanced rods and pistons EJ22E heads; port matched Cometic hybrid HGS Delta 220 cams Grimmspeed Phenolic spacers NGK plugs and wires PageOne Customs grounding kit eBay oil catch can PageOne Customs UEL header Invidia replica exhaust Drivetrain: Exedy KSB04 clutch kit Uncle Scotty's cocktail fluids Group N pitchstop Kartboy shifter bushings PageOne Customs shortshifter Suspension: KYB Excel G struts 2004 STi springs Paranoid Fabrications 3/8" rear saggy butt spacers WRX rear sway bar WRX sedan rear lateral links* Wheels/Brakes: 2005 WRX 16x6.5 rims Accelera Alpha 205/60/16 tires 2002 WRX disc swap* WRX master cylinder and PV swap* Interior: 2003 WRX seats front and rear. Pioneer head unit and door speakers (2) OEM underseat subwoofers ProSport oil pressure gauge WRX Momo steering wheel* WRX pedal covers WRX map lights* (*= bought but not yet installed) Link to comment Share on other sites More sharing options...
oregoncoast Posted December 12, 2012 Share Posted December 12, 2012 Newest race build project. Testing race Frankenmotor in the dunes. 2" strut spacer lift, 205/75R15 Toyo Open Country A/T Paint, cage, custom bumpers to follow... Link to comment Share on other sites More sharing options...
