BlindSight Posted November 2, 2005 Share Posted November 2, 2005 Really need to change my belts:banghead: ....first....what are the best belts to get and where? is it okay to get them from oreillys or autozone? whats the best way to change them out? I was looking through my chiltons and says that on my carbed 87 GL wagon the timing numbers/marks should be on my flywheel? it says there is a piece that covers it...no piece there, guess the cover was gone a long time ago......dont see any sort of markings anywhere... how do I change the belts and time it if I have no marks:confused: ? Sorry for the noob crap...still in automotive classes...havn't gotten around to this stuff yet. THANKS A MILLION FOR ALL OF THE HELP!!!!!!!!!!. Link to comment Share on other sites More sharing options...
MilesFox Posted November 2, 2005 Share Posted November 2, 2005 if you removed the crank pulley and the belt cogs from the crank snout that will be the mark relative to the flywheel, the mark that represents ALL pistons are in the center of their bore. the cams will line up to the notch in the plastic, which will also be the seam for the valve cover gaskets o deg btdc will be the passenger side cam lined up with the corner ridge of the valve cover check this out: http://www.economysuperstar.com/milesfox/subaru/service/timingbelt.htm Link to comment Share on other sites More sharing options...
Snowman Posted November 2, 2005 Share Posted November 2, 2005 Miles' T-belt explanation is pretty good, so I'll leave it at that. DO get OEM belts though. They're not that expensive, and it's worth it to know that you've got the best quality belts in there. Link to comment Share on other sites More sharing options...
NoahDL88 Posted November 2, 2005 Share Posted November 2, 2005 while your in there, cam seals, oil pump seals and a new water pump are cheap insurance. Link to comment Share on other sites More sharing options...
BlindSight Posted November 2, 2005 Author Share Posted November 2, 2005 thanks much everyone, whers the best place to get the oem belts at? Link to comment Share on other sites More sharing options...
hatchsub Posted November 2, 2005 Share Posted November 2, 2005 I would assume go down to your local subaru dealership and have them order them if they don't have them on the shelves collecting dust. Link to comment Share on other sites More sharing options...
BlindSight Posted November 2, 2005 Author Share Posted November 2, 2005 hmmm.....faily far from a subaru dealership...will see what I can find. heres a pic of my belts... ... they run the same path. Can I not just loosen the alternator bolt, slide it down and pul the belts off and put the new ones on and time it? Link to comment Share on other sites More sharing options...
NoahDL88 Posted November 2, 2005 Share Posted November 2, 2005 Those are your "V" belts, no timing required Link to comment Share on other sites More sharing options...
Subarian Posted November 2, 2005 Share Posted November 2, 2005 Those aren't your timing belts- they're your accessory drive belts. The timing belts are located under the black plastic covers on the front of the engine. Link to comment Share on other sites More sharing options...
BlindSight Posted November 2, 2005 Author Share Posted November 2, 2005 AWESOME....see... being stupid and asking questions paid off....thanks a whole bunch for dealing with all of my stupidity everyone....I really really appreciate it. Link to comment Share on other sites More sharing options...
Cougar Posted November 2, 2005 Share Posted November 2, 2005 As the others have mentioned you don't have to worry about timing with the belts in your picture. The timing belts run the cams for the engine and are inside those black plastic covers behind the belts in your picture. The timing belts are supposed to be changed out every 60k miles. I would recommend you get a service manual for your vehicle since you are going to work on it. It will be as valuable to you as your tools are. Ebay is a good source for manuals and you can even get factory ones for a good price. I would try to get the complete set of 4 books for the car. Ebay has a set right now for an '86 which would be close enough for most things on your model. Here is a link for your convenience. If you got these for around $50 dollars it would be a good price. Think how far that money will go for a service shop repair job. Some places charge more than that for just a diagnosis. http://cgi.ebay.com/ebaymotors/1986-SUBARU-SERVICE-MANUAL-SET-COMPLETE_W0QQcmdZViewItemQQcategoryZ6762QQitemZ8011242359QQrdZ1 Link to comment Share on other sites More sharing options...
