Subarian Posted November 2, 2005 Share Posted November 2, 2005 I think I'll replace my timing belts this weekend. I was thinking of going with a 1-notch advance, but I can't remember how many teeth the cam sprockets have. I think it's either 18 or 36. 18 would put it at a 20 degree cam advance- pretty radical. Have any of you tried it? Quote Link to comment Share on other sites More sharing options...
Subarian Posted November 2, 2005 Author Share Posted November 2, 2005 Since no one has apparently tried it, I'll let you know how it works. Since it's a non-interference engine, it won't hurt to try, and I might pick up some serious bottom end. Of course, it might not run. I'll let you know. Quote Link to comment Share on other sites More sharing options...
hooziewhatsit Posted November 2, 2005 Share Posted November 2, 2005 I think that most people that get them a tooth off report back saying it ran like garbage. Feel free to try though Quote Link to comment Share on other sites More sharing options...
TROGDOR! Posted November 2, 2005 Share Posted November 2, 2005 Yes, it'll run like crap. Keep the timing belts lined up properly. Advance your timing with the distributor. Quote Link to comment Share on other sites More sharing options...
Subarian Posted November 2, 2005 Author Share Posted November 2, 2005 Ignition timing is set with the distributor, but there's got to be a way to advance cam timing as well. Advancing cam timing moves the power band and increases low-end torque. It's a great low-bucks mod for small block chevys, and I've seen it on Nissans and Toyotas, but I've never tried it on a Subaru. Quote Link to comment Share on other sites More sharing options...
robm Posted November 2, 2005 Share Posted November 2, 2005 Googling "Advaned cam tiimng" shows that an advanced cam can improve botom end and midrange, but the amount of advance required is very little. No more than 2-3 degrees, typically, and it helps if you can adjust the exhaust separtely from the intake (DOHC). If your 36 tooth sprocket figure is correct, that will give 10 deg. advance, which is a whole bunch more than you can use. Doing this will advance your ignition timing, too. Don't forget to set it back, so you can tell exactly what is going on, and not get the cam and ignition timing effects mixed up. Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted November 2, 2005 Share Posted November 2, 2005 watch your coolant temp, i had my belts a tooth off, and the temp went through the roof Quote Link to comment Share on other sites More sharing options...
Ross Posted November 2, 2005 Share Posted November 2, 2005 10 degrees is way too much. I too have heard of/seen chevy engines with around 2deg of advance, but i doubt it would be too happy with 10deg. Quote Link to comment Share on other sites More sharing options...
Snowman Posted November 2, 2005 Share Posted November 2, 2005 Somebody was making special cam sprockets that made the cam timing adjustable. I don't know if they're available anymore. You might try doing a search for that. I've also gotten belts off a tooth, and the car is barely drivable. Quote Link to comment Share on other sites More sharing options...
Sweet82 Posted November 2, 2005 Share Posted November 2, 2005 Bottom end umph would be good for playing around in the hills? Let us know... Quote Link to comment Share on other sites More sharing options...
Subi81 Posted November 2, 2005 Share Posted November 2, 2005 Ya one tooth off, My car wouldn't idle,freeway wasn't too bad but temps were outta control, way too hot! Quote Link to comment Share on other sites More sharing options...
DirtyMech Posted November 2, 2005 Share Posted November 2, 2005 Hey while were on the subject, has anyone had any experience timing the cam belts without the timing belt covers? My covers broke when I removed the engine for a rebuild, and I decided to keep them off because they're falling apart and oil soaked, etc. But now I don't have those convenient timing marks on the inner covers for when I'm timing the damn thing. Do I just have to do it by eye, or can I use an alternate point of reference? I was thinking about riggin a level somehow to hang it from the cam sprockets. That might do the trick, but I'm not sure if the timing marks on the cam sprockets are perfectly vertical when being timed...I might just end up getting some replacement inner covers from Pick N Pull if I can't figure it out. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted November 3, 2005 Share Posted November 3, 2005 if you had a spare set of pilleys to expend you can try slotting the bolt holes and pin hole to achieve your cam advance the seam for the valve cover gaskets is the same as the plastic mark on the covers also the passenger side cam will line up tp the hard corner on the valve cover for o deg btdc Quote Link to comment Share on other sites More sharing options...
DirtyMech Posted November 3, 2005 Share Posted November 3, 2005 the seam for the valve cover gaskets is the same as the plastic mark on the covers Thanks Miles! I owe ya one. Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted November 3, 2005 Share Posted November 3, 2005 I belive someone on the board made adjustable cam pullies, IIRC there were some pictures, so if you're good with machine tools you might be able to make some yourself, with the pictures as a guide. Quote Link to comment Share on other sites More sharing options...
jono Posted March 29, 2014 Share Posted March 29, 2014 So, is this confirmed? Intentionally advanced by one tooth each side of an EA82, T or NA, correctly ignition timed to suit will run and idle like a bag of poop ??i Quote Link to comment Share on other sites More sharing options...
coxy Posted March 30, 2014 Share Posted March 30, 2014 Any engine be it Toothed Belt or cam chain as the belt stretches or the Cam Chain stretches the cam timing retards and they lose bottom end power but rev out more on top end, This is why some manufacturers like Nissan-Datsun with the L series motors had three optional locations on the cam sprocket the adjust the timing but the amount was about three degrees so in total they had a maximum of six degrees to play with that should be a good guideline as to how much you can play without going backwards In Power Output. Quote Link to comment Share on other sites More sharing options...
