95 Legacy 2wd cv joint axles
I just replaced the drive axles on my 95 Legacy wagon 2wd and ever since then the vehicle has a severe vibration under hard acceleration. The axles I put in were remanufactured and i did notice that the circumference of the original CV housing was larger that that of the replacement ones.
Anybody experienced this? Should I take them back out and try a different brand?
I should also mention that when I replaced a boot on the axle last year, it took a while to find one that would fit, it seemed as though everyones part number listing was incorrect including Subaru's. (they were all too small)
Made me wonder if I had an odd ball car?
Thats too bad that you had trouble with that.What brand axles did you put in?Were they OE or from somewhere else?You may want to give CCR(colorado component rebuilders)a call. I am sure they could either get you some axles or point you in the right direction.Their # 303-293-9230
