Question on turnsignal flasher 85 gl wagon
Working on this car for a friend,
The right turn signal goes nuts, figured it was the flasher under the dash.....
Noise for it is coming from the turnsignal cam assembly in the steering column just behind the steering wheel. Is this where the flasher is located in this one.... Looked in the normal place under the dash and nothing there.
Also the emergency flasher causes this area to click also.....
Hush
