motor/trans mount interchange
Not really......The liquid filled (round) mounts will probably provide more isolation/noise damping. The regular square ones are really pretty soft. The sti mounts use the same mold as the square ones, however the rubber is a much much harder rubber.
  • 4 years later...
Yes the mounts are interchangable. Make sure you get the rubber mount & the mounting bracket. Depending on the type of mount liquid filled (round) or rubber (square) the bracket will be slightly different.
Sorry for the 3 year old thread, but i was curious if anyone had more info on this. I have the liquid filled round ones (atleast they were liquid filled) and they are super expensive.
How different is the bracket for the square ones?
