belizeanbus Posted November 3, 2005 Share Posted November 3, 2005 'Evening... I was looking for the amount of torque to lay onto the oil pump on my EA82 when attaching it to the block. I found that my chilton's simply says to "intall it onto the cylinder block." No specs included. In the section on 2.5L, it says 56 in. lbs. is the way to go. Does anyone know the proper amount to torque this thing down? or should I go with 56? Thanks belizeanbus Link to comment Share on other sites More sharing options...
Ross Posted November 3, 2005 Share Posted November 3, 2005 Find a torque spec for something with bolts of the same size and use that. Link to comment Share on other sites More sharing options...
Qman Posted November 3, 2005 Share Posted November 3, 2005 That sounds pretty close. Just slightly over 4 ft/lbs. I usually just tighten them until they are tight with a very small 3/8" or 1/4" ratchet. Use caution when using this technique though. They are very small and will break easily. Link to comment Share on other sites More sharing options...
MilesFox Posted November 3, 2005 Share Posted November 3, 2005 i second the notion of a 1/4" drive ratchet when not using a torque wrench. you want them hand tight and about 1/4 turn. be careful as the bolt will seem ligke its tightening more but youre twisting it off! torque evenly a little bit each bolt at a time in sequence Link to comment Share on other sites More sharing options...
