Braided brake lines
ShawnW
Can anybody tell me a good place online to order em from, preferably one that they have ordered from themselves? Approx price would be nice too.
If not, specs on what you ordered....I have a 4" kit all the way around on my 83 Turbo. Not a 4/3 like the BYB ones just for clarification.
http://cobbtuning.com/impreza/brakes1.html#lines
http://www.rallitek.com/products.asp?ID=352&ACC=Y
I'm under the impression that the newer brake lines fit on the older subies, its just a matter of finding which ones you want, me, i'd go with the forester kit, cause i would assume that they would be the longest, which would work with the PK lift kit.
But if the bandit with the third eye has them, i always like buying "local"
I just had a set made for my wagon, which has a 4" lift. I brought in original rubber lines and said "4 inches longer here and here." The fronts don't have the fittings that bolt through the strut bracket (a rubber grommet and a zip tie will subsitute nicely) and the back omits the hard line and the 2 sets of fittings associated with that (pass the grommets & zip ties, please!). These omissions were done to save money, as the fittings were the most expensive part. The set cost me $105.
They aren't installed yet as I have to do some other stuff with the calipers first.
  • 2 weeks later...
