Numbchux Posted November 4, 2005 Share Posted November 4, 2005 so I'm in the process of trying to replace the front wheel bearings on my wagon, and it's giving me hell...I'm doin the passenger side, and it just won't come apart! I got the outer oil seal off, and everything else is stuck. the inner seal is just falling apart, but still won't come out, and I can't even get the bearings to budge (I was thinking maybe if I tapped 'em out a bit, the seal might come out easier). Anyway, this if my first time doin this, so it's quite possible I've got something wrong....any ideas? Quote Link to comment Share on other sites More sharing options...
MorganM Posted November 4, 2005 Share Posted November 4, 2005 Need a big chisel and 4+lb hammer. Pound from the inside out. That middle spacer (inbetween your bearings) moves around inside; so you move it to the side, hammer on the inner race of the outside bearing, move it again, hammer on the other side, repeat and work it out. Really need a big vice mounted solid to a bench. So you can secure the knuckle properly and really hammer on it. I couldnt do it in my garage; had to go over to Arch's and use his shop with bigger vise and hammers Quote Link to comment Share on other sites More sharing options...
markjs Posted November 4, 2005 Share Posted November 4, 2005 According to the Haynes manual they'll need to be pressed out at a machine shop. Quote Link to comment Share on other sites More sharing options...
Numbchux Posted November 4, 2005 Author Share Posted November 4, 2005 According to the Haynes manual they'll need to be pressed out at a machine shop. blah blah blah :-p thanks morgan...at least I know I was doing it right Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted November 4, 2005 Share Posted November 4, 2005 I'd reccomend a brass drift, your less likely to hurt the hub as it won't tear into the bearing mount surface. If you don't have them yet, i'd reccoment 207S bearings, there sealed, so if you follow Austin, you're less likely to need to replace them because of water immersion. Quote Link to comment Share on other sites More sharing options...
MorganM Posted November 4, 2005 Share Posted November 4, 2005 I'd reccomend a brass drift, your less likely to hurt the hub as it won't tear into the bearing mount surface. I removed the hubs; if they arent on then you cant damage them. Just a couple bolts and its off. Quote Link to comment Share on other sites More sharing options...
Ross Posted November 4, 2005 Share Posted November 4, 2005 I'd say your making it much harder than it needs to be if you havn't removed the knuckle.... I usually find some good blocks of wood to support the knuckle on the floor. Quote Link to comment Share on other sites More sharing options...
Snowman Posted November 4, 2005 Share Posted November 4, 2005 Put the hub/strut assembly on the floor, get a brass drift, and smack the bejeezus out of it. It sounds like you've got a bunch of rust and crap in there that's holding it up, so a larger hammer may be necessary. BTW, I think the manual just says that as a CYA (cover your...) measure so that if somebody messes up on the bearings and a wheel falls off it's not their fault. I don't know how somebody could mess it up that badly, but I guess anything's possible. Quote Link to comment Share on other sites More sharing options...
Numbchux Posted November 4, 2005 Author Share Posted November 4, 2005 the only reason I haven't removed the knuckle, is I don't have a puller to dissasemble the tie rod, and if this one is anywhere near as difficult as my '85 was....I just don't want to mess with it I did take the control arm loose from the xmember, removed the axle (obviously), and pull the shock out of the knuckle, so it's pretty loose, but I didn't want to mess with the tie rod....I guess I'll try that tomorrow. Quote Link to comment Share on other sites More sharing options...
