jffkoen Posted November 4, 2005 Share Posted November 4, 2005 I have a 98 outback legacy limited w/a dead tape deck. Radio & cd are fine. I am looking to replace it and am having trouble. Any suggestions are welcome. Thanks! jeffrey Link to comment Share on other sites More sharing options...
brus brother Posted November 5, 2005 Share Posted November 5, 2005 If you still want to use the tape deck, open it up and check inasmuch as most of them have a single rubber band belt that make them run. It will be broken and dried out. Check around for a replacement, replace and voila, outdated technology brought back to life... long live the 8 track! Link to comment Share on other sites More sharing options...
jffkoen Posted November 5, 2005 Author Share Posted November 5, 2005 If you still want to use the tape deck, open it up and check inasmuch as most of them have a single rubber band belt that make them run. It will be broken and dried out. Check around for a replacement, replace and voila, outdated technology brought back to life... long live the 8 track! Thank YOU! Link to comment Share on other sites More sharing options...
Commuter Posted November 5, 2005 Share Posted November 5, 2005 Many of us (I have a 97 OB) have put in the newer double DIN 6 CD changer / radio / tape deck. You lose the pocket underneath, but it is worth it. The Subaru Panasonic P123 plugs right in. Same connector. I think the newer ones that came out a couple years ago do as well, but not positive. Commuter Link to comment Share on other sites More sharing options...
jffkoen Posted November 5, 2005 Author Share Posted November 5, 2005 Many of us (I have a 97 OB) have put in the newer double DIN 6 CD changer / radio / tape deck. You lose the pocket underneath, but it is worth it. The Subaru Panasonic P123 plugs right in. Same connector. I think the newer ones that came out a couple years ago do as well, but not positive. Commuter Thank you, where do you locate the cd changer? Is it less convenient than in the dash? jeffrey Link to comment Share on other sites More sharing options...
Gnuman Posted November 5, 2005 Share Posted November 5, 2005 Thank you, where do you locate the cd changer? Is it less convenient than in the dash? jeffrey It is internal to the unit in the dash. The unit mentioned replaces the unit you have, and the storage pocket underneath. Link to comment Share on other sites More sharing options...
