Well my mechanic has used Legacy axles in SVXs as the rebuilder he used retired and he can't find a reliable source. It fits right in there so my guess is it isn't any wider or its only a slight bit that the axles are swappable. If you want a little wider track what about some spacers between the wheel and hub? Should be able to go about a 1/2 inch on either side without getting longer lugs.
i had thought of spacers, but i dont want to prematurely wear out the wheel bearing....... i might just have to space them anyway as the tires i want to run arent going to fit unless i do......
spacers should be just fine. Got ours from summit racing. Still trying to get 275s on our svx.:lol:
