If I Buy A Lift Kit
lil_J
Only time you'll have to change anything (other than lifting your car), is when you put large tires on, then you have to start cutting.
but would i have to change my engine or drivetran
Engine + computer + wireharness.
Even if it's an XT4 NA I wouldnt bother with a motor swap. EA82 MPFI will have
plenty of power to move a lifted XT body and upto 30" tires.
whats a xt4 im new to the subaru thing this is my first subaru
The 4 cylinder or the 4 cylinder turbo is an XT or an XT-Turbo respectively
The XT-6 has the 6 cylinder, a 2.7, basically the 4 cylinder with 2 extra cylinders.
so all i need to buy is a lift kit,rims,tires,turbo and thats all
yea, I only know of one guy running an EA82T on a lifted car...vanislru
and if you're talking about converting your car to turbo, it's alot more complicated, almost as complicated (as far as wiring is concerned) as an H6 swap....not to mention exhaust, oil, coolant lines, intake, etc.
whats a EJ engines
Well you don't need a turbo, its only if you buy a turbo car. I don't think there are to many people running turbos in lifted subaru's most people are putting EJ engines in them.
