lil_J Posted November 9, 2005 Share Posted November 9, 2005 IF I BUY A LIFT KIT FOR MY 89 XT WOULD I HAVE TO CHANGE ANYTHING ON MY CAR HELP ME? Link to comment Share on other sites More sharing options...
kingbobdole Posted November 9, 2005 Share Posted November 9, 2005 Dude... caps lock OFF..... Anyhoo, the EA82 series lift will fit the xt... they are the same Link to comment Share on other sites More sharing options...
Shadyirishmen Posted November 9, 2005 Share Posted November 9, 2005 Only time you'll have to change anything (other than lifting your car), is when you put large tires on, then you have to start cutting. Link to comment Share on other sites More sharing options...
FirstSubaruGLwagon Posted November 9, 2005 Share Posted November 9, 2005 When ordering your lift kit, don't forget to specify what type of transmission and steering you have on the car Link to comment Share on other sites More sharing options...
lil_J Posted November 9, 2005 Author Share Posted November 9, 2005 Shadyirishmen said: Only time you'll have to change anything (other than lifting your car), is when you put large tires on, then you have to start cutting. but would i have to change my engine or drivetran Link to comment Share on other sites More sharing options...
A DOG Posted November 9, 2005 Share Posted November 9, 2005 lil_J said: but would i have to change my engine or drivetran No. Unless you want more power. If you get bigger tires it takes away from your gearing. Making it feel like you lost some power, but not much. Link to comment Share on other sites More sharing options...
lil_J Posted November 9, 2005 Author Share Posted November 9, 2005 if i was to put a XT6 motor in xt would i have to change thing Link to comment Share on other sites More sharing options...
NoahDL88 Posted November 10, 2005 Share Posted November 10, 2005 lil_J said: if i was to put a XT6 motor in xt would i have to change thing yes Link to comment Share on other sites More sharing options...
LosDiosDeVerde86 Posted November 10, 2005 Share Posted November 10, 2005 NoahDL88 said: yes what....the motor? Link to comment Share on other sites More sharing options...
MorganM Posted November 11, 2005 Share Posted November 11, 2005 LosDiosDeVerde86 said: what....the motor? Engine + computer + wireharness. Even if it's an XT4 NA I wouldnt bother with a motor swap. EA82 MPFI will have plenty of power to move a lifted XT body and upto 30" tires. Link to comment Share on other sites More sharing options...
lil_J Posted November 14, 2005 Author Share Posted November 14, 2005 MorganM said: Engine + computer + wireharness. Even if it's an XT4 NA I wouldnt bother with a motor swap. EA82 MPFI will have plenty of power to move a lifted XT body and upto 30" tires. whats a xt4 im new to the subaru thing this is my first subaru Link to comment Share on other sites More sharing options...
ezapar Posted November 14, 2005 Share Posted November 14, 2005 XT turbos look sweet with a little lift. Here's one I had. Link to comment Share on other sites More sharing options...
NoahDL88 Posted November 14, 2005 Share Posted November 14, 2005 lil_J said: whats a xt4 im new to the subaru thing this is my first subaru The 4 cylinder or the 4 cylinder turbo is an XT or an XT-Turbo respectively The XT-6 has the 6 cylinder, a 2.7, basically the 4 cylinder with 2 extra cylinders. Link to comment Share on other sites More sharing options...
lil_J Posted November 15, 2005 Author Share Posted November 15, 2005 NoahDL88 said: The 4 cylinder or the 4 cylinder turbo is an XT or an XT-Turbo respectively The XT-6 has the 6 cylinder, a 2.7, basically the 4 cylinder with 2 extra cylinders. so all i need to buy is a lift kit,rims,tires,turbo and thats all Link to comment Share on other sites More sharing options...
Shadyirishmen Posted November 15, 2005 Share Posted November 15, 2005 Well you don't need a turbo, its only if you buy a turbo car. I don't think there are to many people running turbos in lifted subaru's most people are putting EJ engines in them. Link to comment Share on other sites More sharing options...
Numbchux Posted November 15, 2005 Share Posted November 15, 2005 yea, I only know of one guy running an EA82T on a lifted car...vanislru and if you're talking about converting your car to turbo, it's alot more complicated, almost as complicated (as far as wiring is concerned) as an H6 swap....not to mention exhaust, oil, coolant lines, intake, etc. Link to comment Share on other sites More sharing options...
lil_J Posted November 16, 2005 Author Share Posted November 16, 2005 whats a EJ engines Shadyirishmen said: Well you don't need a turbo, its only if you buy a turbo car. I don't think there are to many people running turbos in lifted subaru's most people are putting EJ engines in them. Link to comment Share on other sites More sharing options...
