Overthehill Posted November 9, 2005 Share Posted November 9, 2005 Just bought a new 2006 Outback. WOW. I'm hooked. Put 1000 miles on the first week. Can't get enough. One of you Soobie nuts who are obsessed as I'm becoming must know how to SHUT THIS !@#$ Seatbelt alarm off. Dealer says against the law to shut it off or tell me how. Maybe, Maybe not. But there is always other ways. There are times when I just can't wear it even most of the time I do. Thanks Overthehill. Link to comment Share on other sites More sharing options...
TheBrian Posted November 9, 2005 Share Posted November 9, 2005 I'm no lawyer, but disabling the alarm would be defeating a safety device. Your insurance company may prohibit that, and for all I know it might even be illegal. Defeating the chime would be simple, but don't do it. Crashing the car without a seatbelt is Bad For You. So wear a seatbelt all the time. And if there's some bizarre reason you can't wear a seatbelt, then buckle the seatbelt in and sit on top of it. Link to comment Share on other sites More sharing options...
nipper Posted November 9, 2005 Share Posted November 9, 2005 There is a weird on off way of doing it ... let me see if i can find the way of doing it. Its a luducrously complicated method of on of's if i remeber correctly. found it.... The seatbelt chime can be turned off by the user. Just turn the key to the ACC position and begin buckling and unbuckling the seat belt as soon as the chimes start. Remember to wait until the seatbelt icon stops blinking before unbuckling. Repeat twenty buckle/unbuckle repetitions and remove the key. The chimes should be disabled the next time you start the engine. The process seems to be finicky so you may need to repeat it several times before it takes hold. this is from an edmunds board on outbacks nipper Link to comment Share on other sites More sharing options...
Overthehill Posted November 9, 2005 Author Share Posted November 9, 2005 Thanks Nipper. I will give it a try and let you know how it went. Overthehill There is a weird on off way of doing it ... let me see if i can find the way of doing it. Its a luducrously complicated method of on of's if i remeber correctly. found it.... The seatbelt chime can be turned off by the user. Just turn the key to the ACC position and begin buckling and unbuckling the seat belt as soon as the chimes start. Remember to wait until the seatbelt icon stops blinking before unbuckling. Repeat twenty buckle/unbuckle repetitions and remove the key. The chimes should be disabled the next time you start the engine. The process seems to be finicky so you may need to repeat it several times before it takes hold. this is from an edmunds board on outbacks nipper Link to comment Share on other sites More sharing options...
Overthehill Posted November 9, 2005 Author Share Posted November 9, 2005 OK Nip pretty funny. After trying about 10 times I get no results. If this is a joke I'm laughing with you. If not it doesn't seem to work. What's the scoop. Overthehill Thanks Nipper. I will give it a try and let you know how it went. Overthehill Link to comment Share on other sites More sharing options...
nipper Posted November 9, 2005 Share Posted November 9, 2005 Not a joke i can give you the original source if you want (once my email puter kicks in).... its touchy, sometimes it works and sometimes it doesn't. Otherwise you just live with it. I only joke iif it envlovles slaughtering a small animla and chanting over the engine computer on a full moon with ans easterly wind.... nipper Link to comment Share on other sites More sharing options...
NoahDL88 Posted November 9, 2005 Share Posted November 9, 2005 It occurs to me that there is no good reason to not wear your seatbelt. Pardon my french, but you'd be a Dumb @$$ to not wear it. Link to comment Share on other sites More sharing options...
nipper Posted November 9, 2005 Share Posted November 9, 2005 Ok here is the original email i got from a yahaoo list.... And it talks of sitting there with the car running in park nipper To: outback@yahoogroups.com Sent: Wednesday, October 05, 2005 8:22 AM Subject: RE: [outback] stopping 05 Outback seatbelt chime? Rich: I don't have time to find the posting right now but on one of the Edmunds Town Forum boards there are directions on how to turn it off. I believe it is in a 2005 Outback discussion board. I saved one of the messages, hopefully this will be enough detail. If it does not work let me know. I think this needs to be done within a 30 second time period. Here is the cut and paste: The seatbelt chime can be turned off by the user. Just turn the key to the ACC position and begin buckling and unbuckling the seat belt as soon as the chimes start. Remember to wait until the seatbelt icon stops blinking before unbuckling. Repeat twenty buckle/unbuckle repetitions and remove the key. The chimes should be disabled the next time you start the engine. The process seems to be finicky so you may need to repeat it several times before it takes hold. Good luck. Karl > -----Original Message----- > From: outback@yahoogroups.com > [mailto:outback@yahoogroups.com] On Behalf Of Rich Rubel > Sent: Tuesday, October 04, 2005 9:05 PM > To: outback@yahoogroups.com > Subject: [outback] stopping 05 Outback seatbelt chime? > > Just got an email off-list from someone wondering if there's > a way to turn off the intermittent seatbelt chime/flash > reminder in an 05 Outback. Not that they plan to drive w/out > belts, but even if you're sitting somewhere with the engine > running and the car in park, you get the chime. > > Anyone got an idea? > Thanks. > [RICHR] To subscribe/un-subscribe vist http://groups.yahoo.com/group/outback Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted November 9, 2005 Share Posted November 9, 2005 First - it isn't a joke, I just did it in my '06 WRX wagon. It will not disable the initial chime - just the repeat chiming. I used the 'on' postion. dunno if ACC works or not. I did the buckle/unbuckle starting immediately after switching to the 'on' (not starting though) position. I probably did it over 20 times in under 30 seconds, confriming that the warning light in the gauge cluster went off each time. It helps to sit on part of the belt after pulling it all the way out or otherwise prevent the retraction spring from pulling on you during the procedure. I postioned my right hand on the release button and concentrated left hand duties for insertion and 'catching' the tab when ejected after pressing the release button. I HAVE read of folks trying multiple times to get it to work. Perhaps I was just lucky. haven't tried it on the wife's '03 OBW so I don't know what years' cars this is effective on. fyi Link to comment Share on other sites More sharing options...
mikem Posted November 9, 2005 Share Posted November 9, 2005 I did the seat belt repetitive chime disable routine on my 06 outback and it worked. Chimes once. That's it. Life is good. And quiet. Link to comment Share on other sites More sharing options...
nipper Posted November 9, 2005 Share Posted November 9, 2005 YAY nipper Link to comment Share on other sites More sharing options...
gadberry Posted November 26, 2010 Share Posted November 26, 2010 I just had to repeat this on my 2006 outback after a dealer reset So with the seatbelt disconnected, switch key to ON position, then begin the 20 insert/remove procedure, After unclicking the last time, turn the key forward and start the car before switching it off. That did it for me but it took 2 attempts... I wear the belt while driving but having that darn alarm disabled definitely is the secret to lifelong happiness and well-being.... Ha! Peace be with Link to comment Share on other sites More sharing options...
mw5756 Posted September 2, 2012 Share Posted September 2, 2012 Worked on my 06 Outback first attempt, yea! There are times when I'm in my car with it running and i'm not wearing my seatbelt. Example, my wife and I are taking a break and she's nursing my son and we got the a/c on....don't need to wear a seatbelt in the parking lot. Link to comment Share on other sites More sharing options...
Legacy777 Posted September 4, 2012 Share Posted September 4, 2012 Yeah, I did this on my 06 Legacy when I had it. The seat belt chime is so freaking annoying! Just an FYI for those folks that haven't owned a newer Subie, the seatbelt chime goes off if you just sitting there parked with the engine on. I agree you should definitely wear your seatbelt, but if you're doing some testing or other type stuff where the engine is running and the car is sitting there, you want to rip out the seat belt chime....that's how annoying it is Link to comment Share on other sites More sharing options...
spazomatic Posted September 5, 2012 Share Posted September 5, 2012 I did this on my baja too. That chime is bad enough to make a man want to return the thing to the dealer and get a refund! Why, oh why does it need to chime when its running and in park? But yeah, it took two attempts at this method to get it to work. Aaah, peace and quiet Link to comment Share on other sites More sharing options...
lesstutrey Posted September 6, 2012 Share Posted September 6, 2012 hmm... wonder if there was something similar done with 02 outbacks, i got mine used and always wondered why it didn't do seatbelt alarm/light for more than a few seconds when i start it. Link to comment Share on other sites More sharing options...
nickb21 Posted September 6, 2012 Share Posted September 6, 2012 My '02 OBW is the same as yours. I guess we are the lucky ones that get to enjoy a few short, quiet dings, and then not have to be annoyed. I'm sure it changed at least in '05+ in US Legacy's/OB's. hmm... wonder if there was something similar done with 02 outbacks, i got mine used and always wondered why it didn't do seatbelt alarm/light for more than a few seconds when i start it. Link to comment Share on other sites More sharing options...
