herman Posted November 9, 2005 Share Posted November 9, 2005 I have two things going on and I don't know if they are related or not. The first on I've had from the get-go. The radio will loose volume from time to time and also will have to have its display settings reset. Like when the battery has been disconnected. Although anoying it can be lived with. The other problem happens when I try to start the car. I turn the key and all I hear is one click. I have been able to continue "clicking" the starter until it turns over. Once in a while the starter will seem to "drag". Where should I start trouble shooting, or has someone else had the same problems and how were they corrected. thanks for reading this herman Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted November 9, 2005 Share Posted November 9, 2005 Sounds like you may have a bad ground with your radio.Is it stock or aftermarket?Also what car is it that you have?Your starter may have a bad ground too,or maybe the contacts are worn on the starter and that may cause it to stick.Goodluck. Link to comment Share on other sites More sharing options...
herman Posted November 9, 2005 Author Share Posted November 9, 2005 '92 16 valve 5speed legacy all wheel drive. I hurt my back a few years back and am no longer to crawl around before that I had been wrenching and doing all my own work, now I have to farm it out. Hurts the pocket book but keeps the back from knocking me down Link to comment Share on other sites More sharing options...
