jake_b Posted November 11, 2005 Share Posted November 11, 2005 Hi all, I have just spent a good while reading old threads about the speedometers in the 1999 OBW failing, but I can't seem to find one with my particular symptoms... My car: 99 Leagacy Outback Wagon 2.5l 5-speed manual approx. 117,000mi (analog odometer) -Cruise control totally non-functioning (even when the speedo is working) -Speedo/Odo stop working at the same time -No CEL -Tapping the dash (ok... you got me -- pounding on the dash with fist) does not work -Started failing occasionally, but is to the point where it will come on for only 10-25% of the time -All other gagues work fine (I use my Tach as my speedo...) Okay... so, what do you think? What kind of money do you think I have to drop to get this fixed? Thank you so much for your help. jake Link to comment Share on other sites More sharing options...
Subie Gal Posted November 11, 2005 Share Posted November 11, 2005 i think... the car needs to be properly diagnosed all we can do is guess. speedo head? speedo cable? sensor? hard to say you're probably going to need to get the car looked at. Jamie Link to comment Share on other sites More sharing options...
Roamer Posted November 11, 2005 Share Posted November 11, 2005 On my former 1990 legacy this happened once, it was basically the speed cable that runs into the top of the transmission. You should check 1st to see that this cable is actually attached, if it is then you should pull it and then place the car on a lift and run it in first gear. While the car is running look inside the tranny unit and you should be able to see a gear/nut turning this is what turns the speed cable and transmits the info to your dash. If this thing is turning you have a bad cable, if it is not you have a bad I dont know what, but it requires some minor transmission work. I am not a mechanic so I hope this made sense to you? Hi all, I have just spent a good while reading old threads about the speedometers in the 1999 OBW failing, but I can't seem to find one with my particular symptoms... My car: 99 Leagacy Outback Wagon 2.5l 5-speed manual approx. 117,000mi (analog odometer) -Cruise control totally non-functioning (even when the speedo is working) -Speedo/Odo stop working at the same time -No CEL -Tapping the dash (ok... you got me -- pounding on the dash with fist) does not work -Started failing occasionally, but is to the point where it will come on for only 10-25% of the time -All other gagues work fine (I use my Tach as my speedo...) Okay... so, what do you think? What kind of money do you think I have to drop to get this fixed? Thank you so much for your help. jake Link to comment Share on other sites More sharing options...
nipper Posted November 11, 2005 Share Posted November 11, 2005 except a 99 doesnt use a spedo cable. i would guess the speed snsor on the outputshaft of the transmission .. if there is such a thing. Where ecer the car picks up its speed from is dead or the connetor is shot. nipper Link to comment Share on other sites More sharing options...
Subarunation 713 Posted November 12, 2005 Share Posted November 12, 2005 Hi all, I have just spent a good while reading old threads about the speedometers in the 1999 OBW failing, but I can't seem to find one with my particular symptoms... My car: 99 Leagacy Outback Wagon 2.5l 5-speed manual approx. 117,000mi (analog odometer) -Cruise control totally non-functioning (even when the speedo is working) -Speedo/Odo stop working at the same time -No CEL -Tapping the dash (ok... you got me -- pounding on the dash with fist) does not work -Started failing occasionally, but is to the point where it will come on for only 10-25% of the time -All other gagues work fine (I use my Tach as my speedo...) Okay... so, what do you think? What kind of money do you think I have to drop to get this fixed? Thank you so much for your help. jake I have a 99 Legacy sedan 2.2 5 speed with some of the same problems, speedo/odo works 60-70% of the time. Cruise always works. If I tap the winshield washer button the speedo comes back to life most of the time. There was a post about 10-14 months ago about this same problem. I thought I had saved it because it had instructions on how to adjust the odo if you picked up an used speedo head. Check fuses on the cruise. If you have intermittent speedo/odo functions and no cruise you may have a speed sensor problem. That piece is on the transmission. Get an 8# sledge hammer, wind up with a full swing and tap the transmission :-) I know my problem is speedo head so I did not investigate the speed sensor issue on the transmission.Good luck, Greg Link to comment Share on other sites More sharing options...
jake_b Posted November 22, 2005 Author Share Posted November 22, 2005 Check fuses on the cruise. If you have intermittent speedo/odo functions and no cruise you may have a speed sensor problem. That piece is on the transmission. Get an 8# sledge hammer, wind up with a full swing and tap the transmission :-) I know my problem is speedo head so I did not investigate the speed sensor issue on the transmission.Good luck, Greg The fuse for the cruise is fine... From what I have read, I think it is definitely my VSS. Besides beating on my tranny with a sledge, is there anything I can do personally to fix this? Can I replace the speed sensor module on the outside of the transmission, or does it require dropping the tranny/taking it apart to get at the VSS? Has anyone paid to have this fixed? What kind of change do this I would have dishing out? Thanks again. jake edit: Found this: http://autorepair.about.com/library/a/1h/bl833h.htm?terms=vss+subaru . It references an auto tran, but is this valid for the manual as well? Link to comment Share on other sites More sharing options...
f15xxx Posted November 25, 2005 Share Posted November 25, 2005 you too, buy a new speedo. this is common for 99my. a c-note will solve yer problem. Link to comment Share on other sites More sharing options...
john in KY Posted November 26, 2005 Share Posted November 26, 2005 [quote Can I replace the speed sensor module on the outside of the transmission Yes. It just screws out. New one costs about $150. Link to comment Share on other sites More sharing options...
