Island Roo Posted November 12, 2005 Share Posted November 12, 2005 can i put a regulaar dash from a 92 into my 85 turbo w/ digidash? what will i need to change? or should i try to get a reg dash from same year car? Quote Link to comment Share on other sites More sharing options...
hooziewhatsit Posted November 12, 2005 Share Posted November 12, 2005 the connectors are very different between the two. I'm sure it's been done before, it probably just won't be the easiest. Best bet would be to get a dash from a similar car. Quote Link to comment Share on other sites More sharing options...
Island Roo Posted November 12, 2005 Author Share Posted November 12, 2005 you mean connectors between the two years or between digi and analog? Quote Link to comment Share on other sites More sharing options...
hooziewhatsit Posted November 12, 2005 Share Posted November 12, 2005 you mean connectors between the two years or between digi and analog? both :/ I also have an 85 twagon, I don't recall right now how the connectors were different, I just know they are. Also, the two two dashes (analog vs. digital) usually have different gauges in them. ie, my 85 digi doesn't have oil pressure or voltage, but my 91 loyale (same as GLs) have both voltage & oil pressure. Here's a thread where he does a similar swap http://www.ultimatesubaru.org/forum/showthread.php?t=21881&highlight=dash+swap so yes, it can be done, but it's not just plug & play. Quote Link to comment Share on other sites More sharing options...
Subi81 Posted November 12, 2005 Share Posted November 12, 2005 I have done the swap from an analog 89 RX dash to an 86 turbo wagon, digi, and it took some time. Here is a gallery that has pics of the swap and the haness that I had to fabricate. Basically you have to do a lot of splicing wires and figgureing out the circuits. Not trying to discurrage you but you might be able to use some of my notes as a guide. Feel free to ask any questions. I might have some more pics if you need them and I have a 86 FSM wireing guild if you need some pics of it to help you out. http://www.ultimatesubaru.org/photos/showgallery.php?cat=626 Quote Link to comment Share on other sites More sharing options...
