Questions about things in engine..
Hello All got a couple of questions to help me finish up my engine swap.
1. See picture below. What does that thing go to?? ive never seen one before? This is a SOHC 2.5 litre from a 2000 forrester
2. I think this is the Dropping Resistor for automatics. THis is in from an AT 97 impreza...Any ideas
Thanks for the help
Cory
1st picture looks like the motor was from an automatic. The automatic Foresters come with an Oil cooler. It's a finned cooler which uses engine coolant. The cooler mounts between the block and filter. It has a coolant hose attached to that 1st picture on the block, the other side goes to an extra connection on the gooseneck where the thermostat is.
In other words, when you have the oil cooler, your gooseneck is different. A hose and tube run across the bottom front of the engine to the Oil Cooler, then exit there and enter the block where you see the nipple.
If you are not going to use it, just install a plug in the block and either a cap over the extra fitting on the gooseneck or use a gooseneck without the extra fitting.
