Need Advice, Knuckle onto Axle?
I finally got all the new bearings greased up along with the seals for the front wheel bearings. They are pressed into the knuckle, but now I can't get the knuckle back on the axle. I don't have the special tool that the FSM suggests using. I need this car to drive back to school tonight, so if anyone has a trick or suggestion, please lay it on me!
usually the axle will go far enough through the knuckle to get the axle nut on. After that, I place a big crescent wrench right by the seal on the knuckle to pry off of. This protects the seal. Then I use a claw hammer prying on the wrench to pull the axle through, occasionally screwing in the axle nut, etc, to get more leverage.
good luck (had to type quick, dinners ready :) )
Make sure the spacer is lined up and then push from the inboard side by hand. It may help to have a friend take a 6" socket extension and hold it inside the bearings as you push the axle thru to keep the spacer lined up and everything from binding.
