WoodsWagon Posted February 16, 2006 Share Posted February 16, 2006 97mph, downhill SPFI EA82 5spd with 30" mud king tires. With the check engine light on. Burtonsnowman- I bet the tires on my car were as loud as the exhaust on the legacy. They are insanely loud. The thing to consider most about speed is the tires you have on the car. many tires are not rated for speeds over 85 mph, meaning that tread separation and carcass failure are possibilities. So doing 150mph on tires that were ment for <85 is stupid. I can gaurantee you will not maintain controll if a tire disintegrates at that speed. Link to comment Share on other sites More sharing options...
bgd73 Posted February 16, 2006 Share Posted February 16, 2006 91loyale: very good point. I found tires of 13 inch that match 14 inch 60 series tread will do high speed for a very long time. Depending on brand and how measured, 185/75/13 and up do quite well. Link to comment Share on other sites More sharing options...
burtonsnowman Posted February 16, 2006 Share Posted February 16, 2006 I had a bald tire separate at 77MPH in my hatch--scary. Link to comment Share on other sites More sharing options...
Steveman09 Posted February 17, 2006 Share Posted February 17, 2006 With my 3AT when I was stock 97mph. After the rebuild with 3AT and 10psi 110mph topped out in 3rd gear After 5-speed D/R 3.90 Swap and 10psi 115mph After Injectors, Engine Managment, MSD Coil, 2.25inch Exhaust, Gutted Air Box, and 7psi 125mph. At 125 it didnt feel good at all, the air ride is just too soft and the tires are too small at those speeds it gets unstable, not to mention the wind drags the crap out of my car and throws it all over the place. The engine has the power but the car REALLY needs to be lower and stiffened up before its worthy of speeds over 100mph. My 90 Acura Legend L Coupe 5-speed with Intake, Full Exhaust, Advanced Timing, Sports suspension and Brembo Racing Brakes has been up to 150mph (5th gear revlimter) several times without a problem and stayed very well mannered. The suubies have the gears but they dont have the control so I'll never attempt 120+ in my subaru, its just not built for it. Link to comment Share on other sites More sharing options...
WJM Posted February 17, 2006 Share Posted February 17, 2006 '130+' in the RX with the EA82T...the speedo sorta ended....but RPMs kept going to ~7200. 112 in the outback...aka stock speed limiter. Plenty left tho. Link to comment Share on other sites More sharing options...
Tyler_Seattle Posted February 17, 2006 Share Posted February 17, 2006 i have the EXACT same car as you 87 gl non-turbo 2wd 5 speed and i got up to 80.... Link to comment Share on other sites More sharing options...
Pictzie Posted February 18, 2006 Share Posted February 18, 2006 These are slightly different cars, but I've had my fiancee's '93 Loyal(4wd 5sp) at 90mph, as fast as it would go on flat ground, my sold(and now reowned) '88 GL would pull past 90mph, but I ran out of guts. My '92 Loyal(2wd auto) has pushed 100mph and was still pulling, but I've been tinkering with it........ Don Pictzie Link to comment Share on other sites More sharing options...
LPGsuperchargedBrumby Posted February 18, 2006 Share Posted February 18, 2006 my brumby will do 44km\h in reverse i've still got the ticket (i was in a 30km\h zone..road repair zone) Link to comment Share on other sites More sharing options...
