astro Posted November 14, 2005 Share Posted November 14, 2005 my check engine light has been coming on and off - mechanic says it is the knock sensor and a dealership can reset it. Anyone have an idea of what it costs and how long it takes? it is a subaru 2001 legacy sedan with 38K miles ps: do they have to replace the actual part or can the code just be reset to fix the problem? Dealership says it is $180 to replace part and would take 1 1/2 hours, but I was under the impression from the mechanic that it was simpler than this to fix. any advice to help me not get ripped off would be appreciated. Link to comment Share on other sites More sharing options...
RenaissanceMan Posted November 14, 2005 Share Posted November 14, 2005 welcome to the board. Replacing the knock sensor if you know where it is, is really not that difficult and should cost somewhere around $60-70 retail for a replacement one, HOWEVER this is the historic subaru forum and meant for vehicles 79 an older (81 for the brat) -Mike Link to comment Share on other sites More sharing options...
NuclearBacon Posted November 14, 2005 Share Posted November 14, 2005 welcome to the board. Replacing the knock sensor if you know where it is, is really not that difficult and should cost somewhere around $60-70 retail for a replacement one, HOWEVER this is the historic subaru forum and meant for vehicles 79 an older (81 for the brat) -Mike i think you're in the wrong place mike he got it right, he's in the NEW subaru forum. I agree, a knock sensor is usually about 70 bucks, and consists of having a 24mm or so socket, unscrewing it from the block, and screwing a new one in. connect your connector...and tada! maybe if you made a sandwitch or something inbetween it'd take an hour and a half... but i doubt it. i'd reccommend getting the part at like www.autopartswarehouse.com and then while you're waiting for the part, find exactly where it is, and get yourself the appripriate socket (24mm is for the old EA82T's... not sure on the new legacys) and you're good to go! Link to comment Share on other sites More sharing options...
mattocs Posted November 15, 2005 Share Posted November 15, 2005 The knock sensor on my 2.2l was $20 or so at Autozone or Advance Auto Parts. Takes about a minute to do as long as you spray down the bolt holding it down with some WD40 or something. Link to comment Share on other sites More sharing options...
Subie Gal Posted November 15, 2005 Share Posted November 15, 2005 We have these in stock (OEM Factory part) they are not too hard to change.... use our OEM catalog to view/order https://www.subarugenuineparts.com/oe_parts_cat.html to to mechanical section choose make: subaru model: legacy Model year: 2001 once you enter the catlog... key word: knock you want the one for the 2.5L ..... hope this helps - Jamie Thomas email: Jamie at chaplins.com http://www.subarugenuineparts.com *************************** http://www.subiegal.com Link to comment Share on other sites More sharing options...
astro Posted November 18, 2005 Author Share Posted November 18, 2005 Can you give directions on how to change it? I don't know where the knock sensor is and so far the only slightly mechanical thing I've done is change a headlight. thanks We have these in stock (OEM Factory part)they are not too hard to change.... use our OEM catalog to view/order https://www.subarugenuineparts.com/oe_parts_cat.html to to mechanical section choose make: subaru model: legacy Model year: 2001 once you enter the catlog... key word: knock you want the one for the 2.5L ..... hope this helps - Jamie Thomas email: Jamie at chaplins.com www.subarugenuineparts.com *************************** www.subiegal.com Link to comment Share on other sites More sharing options...
subaru DR Posted November 20, 2005 Share Posted November 20, 2005 This is an easy one. All you need is a 12mm socket, an extension and a ratchet. open your hood. Look at your accelerator cable and follow it to where it hooks onto your throttle body. Look straight down next to the throttle body. On the top of the block(under the intake manifold) you will see a black barrel with a 12mm bolt in the center of it. It will have 1 wire coming off of it. This is yourr knock sensor. remove the bolt, disconnect the sensor and repaeat in reverse order. You just saved $150.00 bucks. The SUBARU DR Darin Can you give directions on how to change it? I don't know where the knock sensor is and so far the only slightly mechanical thing I've done is change a headlight. thanks Link to comment Share on other sites More sharing options...
