subie94 Posted November 17, 2005 Share Posted November 17, 2005 i just had another spark-plug blow out though it's not the same subaru.it happened the first time on my 92 legacy(that was my fault,the plug kept coming loose short after i'd tighten it) this time i'm just driving along then POP then she starts to run really sh*ty.you can smell the gas coming out of the spark plug hole and it almost sounded like an exhaust leak. well i pull over real quick an open the hood,i see the plug laying there and go to reach for it to inspect it(it falls before i could get it,out of reach now) first time this happened,plug wire held onto plug,not this time.for some reason that small nipple on top of the plug came off and was stuck in the wire(got it out) now i have to hali-coil another spark-plug back in. if things weren't bad enough with me being out of work an all. (still can't find that dang plug,i think it landed on the cross-member under the engine or somewhere out of sight an reach) Link to comment Share on other sites More sharing options...
Cougar Posted November 17, 2005 Share Posted November 17, 2005 It kind of amazes me to hear about these incidents. I have never seen this kind of thing happen. If you need some help with this perhaps there is a member nearby that can help you out. Sorry to hear about the work situation but something will come along. Link to comment Share on other sites More sharing options...
subie94 Posted November 17, 2005 Author Share Posted November 17, 2005 It kind of amazes me to hear about these incidents. I have never seen this kind of thing happen. If you need some help with this perhaps there is a member nearby that can help you out.. really annoying when it happens .i have my mech coming over tomorrow(i hope) he's helped me the first time. Sorry to hear about the work situation but something will come along. i have a interview with lowes tomorrow,crossing my fingers. weeks before the first time happened.i was hearing a tick,turns out the tick was the loose plug.maybe that's what was causing the tick this time around.maybe it's not a lifter. Link to comment Share on other sites More sharing options...
tunered Posted November 17, 2005 Share Posted November 17, 2005 im going to email you every 30 days and remind you to tighten spark plugs. Link to comment Share on other sites More sharing options...
subie94 Posted November 17, 2005 Author Share Posted November 17, 2005 im going to email you every 30 days and remind you to tighten spark plugs. :-p yup probably still forget to check Link to comment Share on other sites More sharing options...
subie94 Posted November 17, 2005 Author Share Posted November 17, 2005 i just wanted to update.it has been heli-coiled an it's all bk together.i gotta let it sit over night so the thread locker has time to set-up.(thread locked the sleeve in) Link to comment Share on other sites More sharing options...
Chef Posted November 18, 2005 Share Posted November 18, 2005 I've never actually had this problem, but when I first bought my subie one of the spark plugs was actually loose and nearly rattling (plug #1 I think). Noticed it when I decided to just change them. Hopefully some thread locker will do the trick! i just wanted to update.it has been heli-coiled an it's all bk together.i gotta let it sit over night so the thread locker has time to set-up.(thread locked the sleeve in) Link to comment Share on other sites More sharing options...
subie94 Posted November 18, 2005 Author Share Posted November 18, 2005 plug num 1 is the left side (drivers-side) front plug? am i correct cause that's the one that popped out on me.(this time) Link to comment Share on other sites More sharing options...
tunered Posted November 18, 2005 Share Posted November 18, 2005 where did all the shavings go when you drilled and tapped for the heli cor? Link to comment Share on other sites More sharing options...
subie94 Posted November 18, 2005 Author Share Posted November 18, 2005 where did all the shavings go when you drilled and tapped for the heli cor? didn't really drill.the tap we used bored out the bad threads and also tapped in new threads for the sleeve that the spark-plug screws into. we put lithium grease(?) on the tap which caught most of the shavings.any that were missed were picked out with a flat head screw-driver with some of the grease on it so the shavings would stick.then i hooked up the battery and cranked it till it just started to blow out anything else missed. Link to comment Share on other sites More sharing options...
Cougar Posted November 18, 2005 Share Posted November 18, 2005 Plug #1 is on the front passenger side. The one you worked on is #2. plug num 1 is the left side (drivers-side) front plug? am i correct cause that's the one that popped out on me.(this time) Link to comment Share on other sites More sharing options...
subie94 Posted November 18, 2005 Author Share Posted November 18, 2005 Plug #1 is on the front passenger side. The one you worked on is #2. ok that's the one(num 1) that i had to deal with the first time on my 92 legacy ok she's all fixed now,plus no ticking:banana: Link to comment Share on other sites More sharing options...
