quick q's before engine drop-in
put the motor together as much as you can before dropping it in!
all of me experiences the motor comes out or goes in withthe turbo and cross pipe installed. especially with the little bracket that mounts to the head, and the oil return line, much easier to install before dropping the motor
even if the intake is not installed yet, you can put on the turbo anyway
once the motor is in, slide the downpipe onto the turbo studs before drawing up the bellhousing all the way. the downpipe itself mounts to the side of the tranny, so long as its mounted to the tranny before the motor was taken out, it will align right up when the motor goes in
if you never had installed amotor yet, place a jack under the tranny so the engine studs can align without the motor mounts catching the frame
