TROGDOR! Posted November 18, 2005 Share Posted November 18, 2005 So this is the big weekend... the engine is going into my project RX. The car has been sitting for 2 years, but the engine and all attached parts have been removed, and the engine and all accessories going into it have only been sitting for 6 weeks and are proven to be good. So, I have an engineless chassis that has been sitting. What should I check? Anything else to replace/watch out for? None of the brakes are frozen up, and the gas tank needs to be drained. That's all we can say for sure. Tips? Link to comment Share on other sites More sharing options...
hatchsub Posted November 18, 2005 Share Posted November 18, 2005 Fuel filters. Always a good idea to change them up after a time like that. Link to comment Share on other sites More sharing options...
Ever Victorious Posted November 18, 2005 Share Posted November 18, 2005 So this is the big weekend... the engine is going into my project RX. The car has been sitting for 2 years, but the engine and all attached parts have been removed, and the engine and all accessories going into it have only been sitting for 6 weeks and are proven to be good. So, I have an engineless chassis that has been sitting. What should I check? Anything else to replace/watch out for? None of the brakes are frozen up, and the gas tank needs to be drained. That's all we can say for sure. Tips? I recently brought back a car from the dead (6 years), and the only things not directly attached to the engine I had to do were drain the gas tank, and replace the battery. most of what I did was fluids/filters/adjustments on the engine itself. And it runs great. Link to comment Share on other sites More sharing options...
Subarian Posted November 18, 2005 Share Posted November 18, 2005 I'd look over the tires carefully, too. Pay attention to how they roll when you get started. Link to comment Share on other sites More sharing options...
TROGDOR! Posted November 18, 2005 Author Share Posted November 18, 2005 Oh, forgot to mention that too. The tires are shot, and I have a set with under 10k miles on them that are known to be good that are going on it. Probably will inspect the inner fender area of each wheel while I have the wheel off as well. Link to comment Share on other sites More sharing options...
Subaru Jim Maple Ridge Posted November 18, 2005 Share Posted November 18, 2005 The one little trick you should do is to remove all of your fuses and spray the panel with WD40 or electromotive spray. You will never know the miseries you are avoiding. I recently forgot and spent a day and a half trying to track downa headlight that intermittently went dim, yet all the wires checked out OK. After replacing the entire circuit, it ended up being a corroded tip on the fuse. Link to comment Share on other sites More sharing options...
Subaru Jim Maple Ridge Posted November 18, 2005 Share Posted November 18, 2005 Check all of your fuses and maybe spray your panel. Link to comment Share on other sites More sharing options...
gbrand Posted November 18, 2005 Share Posted November 18, 2005 Might not hurt to flush out brake system too. And lube all door hinges/latches, etc. And silicone sppray any rubber mouldings Link to comment Share on other sites More sharing options...
stumpy Posted November 18, 2005 Share Posted November 18, 2005 I had good lucky with a K5 Blazer that sat for 9 years in one of my sheds. Only had 18K on a built motor and trans. The first time I opened the hood it was one big nest!(Rats or squirels?) After I cleaned that all out I taped up some electrical lines and spark plug wires that were chewed to the core, replaced some vaccum lines, change oil and filter, disconected fuel line (Hooked up line to funnel with fresh gas) and the biggie disconnected the heater power as I had it catch fire once before when a mouse built a nest in there next to a coil that heats up and glows red. It was a daily driver when that happened! Mice love duct work to live in. It was so packed I got 2or3 one gallon vaccum loads out of that system and still it dribbles regularly for my friend who I sold it to to buy my first subie. Residuals or did some of the mice go with the sale? Any way it never hurts to see if some unwanted vermin have made a home in there while it has been setting for so long. For what its worth! Stumpy Link to comment Share on other sites More sharing options...
Hondasucks Posted November 18, 2005 Share Posted November 18, 2005 I have faith, I brought back a car that basically sat for 25 years, she purred like a kitten until the fuel pump puked :-P Link to comment Share on other sites More sharing options...
