mieko Posted November 18, 2005 Share Posted November 18, 2005 I was thinking about buying an 81 wagon. The dealer and I cant figure out how to activate the cyclops headlight in the grill. Link to comment Share on other sites More sharing options...
75subie Posted November 18, 2005 Share Posted November 18, 2005 there are no switches around or hanging down?no spare wires?you probly could wire it up to the battery easilly just to see it work. Link to comment Share on other sites More sharing options...
myfinalcoffinx Posted November 18, 2005 Share Posted November 18, 2005 I was thinking about buying an 81 wagon. The dealer and I cant figure out how to activate the cyclops headlight in the grill. Unless you are talking about the EA81, I believe that the cyclops came in 1982. Link to comment Share on other sites More sharing options...
75subie Posted November 18, 2005 Share Posted November 18, 2005 it probly is something someone put in, thats why there is no dash switch Link to comment Share on other sites More sharing options...
Baysurfin Posted November 18, 2005 Share Posted November 18, 2005 If memory serves, the "cyclops" headlight was in the manual considered a "passing light", there should be a "pass" symbol somewhere on one of the column sticks. Its been a while since I had mine, can't remember exactly. Link to comment Share on other sites More sharing options...
chef_tim Posted November 18, 2005 Share Posted November 18, 2005 Lower left dash, should be a blue button with an orange center. IIRC they only work either with or without the high beams on. Later, Tim Link to comment Share on other sites More sharing options...
ShawnW Posted November 18, 2005 Share Posted November 18, 2005 At a minimum the headlight switch needs to be turned on. If you press the button in and flip from hi to low beams you will see what position it lights up the switch in and know when its on. Link to comment Share on other sites More sharing options...
89hatch Posted November 18, 2005 Share Posted November 18, 2005 Where exactly on the lower left dash? I have 2 factory holes that are deletions. Is it supposed to go in one of them? If so, which one? If not, where exactly does it mount? Thanks Link to comment Share on other sites More sharing options...
mcbrat Posted November 18, 2005 Share Posted November 18, 2005 Where exactly on the lower left dash? I have 2 factory holes that are deletions. Is it supposed to go in one of them? If so, which one? If not, where exactly does it mount? Thanks the switch was usually in the right most hole on the left side. Link to comment Share on other sites More sharing options...
Sweet82 Posted November 18, 2005 Share Posted November 18, 2005 My switch says "Center Lamp", I think? If you can't see it behind the logo in the grill, you don't have one. Link to comment Share on other sites More sharing options...
89hatch Posted November 18, 2005 Share Posted November 18, 2005 the switch was usually in the right most hole on the left side. Thanks, McBrat Link to comment Share on other sites More sharing options...
