Temp gauge sending unit sensor...
The 2 pin sensor is right near the thermostat housing. So where is the one pin sensor?
Well I disconnected my 2 pin to test if the gauge moved and the gauge didnt move at all after that when I drove, so that means that the one with the 2 pin is for the gauge on the dash. My car is an 85 so maybe its different and it is a California car with different stuff.
working on an 86 ea82 putting it into an 83 wagon, the one sensor has 2 terminals, but they are the flat spade terminals, so yes, this is your dash gauge
to be correct, one terminal is sideways from the other. this part is the same for ea81 and ea82 carb models, as the ea82 motor in the 83, the 83 plug fits on it the same and the gauge works
my remarks about ea82 spfi would have wires coming out of the sensor, and a green clip
the carb models only have one temp sensor and its for the gauge
