lost my keys
call any dealer...might need to be one in the states, i don't know how the canada/us dealer databases interact. give them the VIN. if the original salesman entered the key code in the computer from the original paper work (which they were supposed to do at the time) then the key code will be available. i've done it on more than one occassion without issue.
if they didn't enter it then pull the 4 digit code from the passenger lock cylinder. all you have to do is remove the door panel, very easy to do. i believe if you know exactly where it is located you can actually get the code without pulling the cylinder out. but...if you have to pull the cylinder out it's only held in place by a clip or something, barely takes any tools to get it out.
