I just installed a new temp gauge quick ?
Its based on what your thermostat temp is if you are measuring the block temp. A reading of 195, 192, 180, and 175 would be common.
I just put in a 192 thermostat, so . . .
Around 190 then?
What temp is "over heating" at?
Thanks for the info!
-=fred=-
if you have enough air in the system or the coolant is so low, wayer wont pass over the sensor. beware of a COLD reading when you know the car is warmed up. same when the heat isnt hot if the coolant ois too low
my sedan leaked at the water pump and i would leave the heat on. once the heat started to get cold it was time to pull over and add another gallon of water
Thanks for the advice!
So far I think she has been doing good.
The temp stays in the 180-190 range.
My heater is working much nicer and she warms up a lot better in the morning.
-=fred=-
What did you use to do this? Is this like a factory water temp or did you use an aftermarket something?
I ask because I have a bad temp guage and I am looking for alternatives. :)
I went down to my local checkers and got a cheap mechanical gauge.
Also be sure that it has a metric adaptor for it; I had the checker's guy open up 3 of them to be sure a got one that would fit in the threaded hole where the factory sending unit was.
But if I where to do it again, I would get the one with the longer heat tubing for the sending unit. Mine was not long enough for a good mounting location so it ending up next to the center of the dash just down from the radio. I did find an easy way to route the hose though the passenger side gromet.
To get a new factory one is $$.
To get a new electric gauge is $$.
Plus my problem is that my dash is unhappy (all sorts of electrical gremlins).
Sooo... I just got a mechanical gauge and it's doing the job great!
-=fred=-
-=fred=-
Do you have a part #?
