Boo-Boo Posted November 22, 2005 Share Posted November 22, 2005 The inside of my Loyal smells of exhaust fumes when the heater blower is on and the car is stationary - goes away when the car is in motion. Have had the exhaust checked for cracks, and seems to be OK. Any ideas? Quote Link to comment Share on other sites More sharing options...
Subarian Posted November 22, 2005 Share Posted November 22, 2005 Did you check the gaskets on the exhaust flanges on the heads? It might also be helpful to know what year and engine you have. Quote Link to comment Share on other sites More sharing options...
soobmater Posted November 22, 2005 Share Posted November 22, 2005 yes, definatley check the gaskets, if its a loyal, its definatley a ea82(aleast if its stock it will be) i guess if the gaskets are leaking, fumes could get into the fan blower, and blow fumes inside?? if it goes away when your driving, maybe just because the air is blowing the fumes away from the blower Quote Link to comment Share on other sites More sharing options...
86subaru Posted November 22, 2005 Share Posted November 22, 2005 my guess exhaust gaskets, my 88 turbo needs aleast 1 gasket passanger, and you get alittle fumes and sounds like leak in the front Quote Link to comment Share on other sites More sharing options...
DaveAP Posted November 22, 2005 Share Posted November 22, 2005 Could be oil leaks hitting your exhaust pipe. Quote Link to comment Share on other sites More sharing options...
FirstSubaruGLwagon Posted November 22, 2005 Share Posted November 22, 2005 Check the rubber gromets, or "Drain plugs" under the rear seat and under the floorboards, see if their all thare. I found one missing under the back seat in my subee. Quote Link to comment Share on other sites More sharing options...
Boo-Boo Posted November 22, 2005 Author Share Posted November 22, 2005 Did you check the gaskets on the exhaust flanges on the heads? It might also be helpful to know what year and engine you have. The engine is a 93'....some how the air intake for the blower is sucking up exhaust from somewhere, but the muffler garage said there are no cracks in the system. Visually there appears to be no exhaust leaking out, but I could be wrong. Quote Link to comment Share on other sites More sharing options...
jacobs Posted November 22, 2005 Share Posted November 22, 2005 To check for exhaust leaks, start the engine and take a rag in the palm of your hand, plug the tailpipe to stop the exhaust from coming out. You will be able to hear any leaks. Quote Link to comment Share on other sites More sharing options...
soobmater Posted November 22, 2005 Share Posted November 22, 2005 well i think it will be coming from the y-pipe gasketts, if it leaks there, your not going to notice it towards the muffler. also, it would be a good idea to check those drain plugs Quote Link to comment Share on other sites More sharing options...
wintersubaru Posted November 22, 2005 Share Posted November 22, 2005 Mine leaks at my right side pollution pipe that comes of the the headnear header flanges so check that to Quote Link to comment Share on other sites More sharing options...
Silentpal Posted November 23, 2005 Share Posted November 23, 2005 it might be a exaust leak or the little hose going to your breather element isn't attatched properly. Quote Link to comment Share on other sites More sharing options...
