soobscript Posted November 22, 2005 Share Posted November 22, 2005 Just wanna make sure I hooked stuff up right. 1988 MPFI turbo. On the ignition coil... black wires go to (-) and colored wires go to (+) right? I would think so, but couldn't find any verification. Plus there's this mysterious green dot by the (-) which is what you get when you mix the blue and yellow wires On the fuel lines... hose coming from the fuel filter goes to the center/highest rail, then the left/bottom rail right after the pressure reg. hooks to the hose going under the fuel filter Correct, right? (Someone once said there is no such thing as a stupid question) P.S. - Battery, EVAP, rear cat, and turbo heat shields need to be connected, then fluids go in. Then I get to slap on the front end... Link to comment Share on other sites More sharing options...
