i want dual range 4wd
mickeykreg
I have a 90 Loyale w/5 speed 4wd and would like to retrofit a dual range 5 speed transaxle out of an 88 GL. I'm thinking of getting everything, including the trans, linkages, console, shift levers, bell housing bolts, dirt, etc. from the same donor car that is complete.
Since the body styles are the same it seems pretty straight forward but I'd be interested in hearing from somebody that has done this.
Is rear drive line modification needed? Front CV axles the same? Are mounting systems including cross members, bell housing, clutch stuff, etc. the same? How about exhaust?
The 32mpg at 75 mph is really cool and it makes me nervous to mess with anything but when the trans does finally go I'd like to do this project. Any thoughts would be very welcome
From what I know,
nah not much mods (body) unless you're changing from automatic to manual then there will be mods at the shifter area.. if its manual FWD - 4WD then you have no worries. The bolt holes are already there ready to go to be installed with rear diff.
Before going ahead.. check the fuel tank if there is a inverted hump in the middle then you have no problems fitting rear diff. If it doesn't then you have to change the fuel tank over from 4WD model.
That goes for sedan and wagons.
I think there is a FAQ on this somewhere.
Cheers
AP
