bella Posted November 23, 2005 Share Posted November 23, 2005 I whant to replace it myself and I whant to now how hard it is?....I will lose oil in replacement process.....something need to be adjusted or I just unscrew nuts amd replace gasket. Thanks. Link to comment Share on other sites More sharing options...
soobscript Posted November 23, 2005 Share Posted November 23, 2005 Very easy to do. Unhook any PCV hoses, remove the 10mm bolts, pull off valve cover. No adjustments needed. The torque spec is very low for the bolts beacause of the rubber washers. I don't know about oil loss, but I would like to know and will soon find out. Do the job with the engine cold to minimize oil loss. --Ed Link to comment Share on other sites More sharing options...
bella Posted November 23, 2005 Author Share Posted November 23, 2005 Very easy to do. Unhook any PCV hoses, remove the 10mm bolts, pull off valve cover. No adjustments needed. The torque spec is very low for the bolts beacause of the rubber washers. I don't know about oil loss, but I would like to know and will soon find out. Do the job with the engine cold to minimize oil loss. --Ed Thank you verry much. Link to comment Share on other sites More sharing options...
Bill90Loyale Posted November 23, 2005 Share Posted November 23, 2005 On my loyale, there were four bolts on the passenger side cover and five on the driver side. Access to the fifth one (underneath) was very limited so you just have to be patient with removal and installation of that bolt. Torque is a non-issue as the bolts and rubber washer things are designed to be screwed in until you hit all stop. I used no sealants. Clean up the covers and all mating surfaces until near perfect. Been four years. No leaks. Link to comment Share on other sites More sharing options...
bella Posted November 23, 2005 Author Share Posted November 23, 2005 On my loyale, there were four bolts on the passenger side cover and five on the driver side. Access to the fifth one (underneath) was very limited so you just have to be patient with removal and installation of that bolt. Torque is a non-issue as the bolts and rubber washer things are designed to be screwed in until you hit all stop. I used no sealants. Clean up the covers and all mating surfaces until near perfect. Been four years. No leaks. Thanks man you too:banana: Link to comment Share on other sites More sharing options...
Subarian Posted November 23, 2005 Share Posted November 23, 2005 Oil loss probably won't be much more than what you're already leaking. The cam towers and valve covers are designed to allow oil to drain back into the pan. Link to comment Share on other sites More sharing options...
bella Posted November 28, 2005 Author Share Posted November 28, 2005 Another request please. Here in Romania is very possible to buy from store a wrong spare because.....I don't now:banghead::-\.So can anyone post a scheme or a picture on how is looks like this gaskets???? I'll appreciate allot. Thanks guys. Link to comment Share on other sites More sharing options...
soobscript Posted November 28, 2005 Share Posted November 28, 2005 They are rubber, a few mm thick, same shape as valve cover outline. The side toward the front of the engine has an arch (or hill, or half circle). If you have the front of the car jacked up to do the job, any oil that comes out will be from the bottom rear corner. Just place a towel or rag there as you remove the cover. Link to comment Share on other sites More sharing options...
bella Posted November 28, 2005 Author Share Posted November 28, 2005 They are rubber, a few mm thick, same shape as valve cover outline. The side toward the front of the engine has an arch (or hill, or half circle). If you have the front of the car jacked up to do the job, any oil that comes out will be from the bottom rear corner. Just place a towel or rag there as you remove the cover. Thanks and hope you will solve the shaking problem. Link to comment Share on other sites More sharing options...
somick Posted December 3, 2005 Share Posted December 3, 2005 Another request please. Here in Romania is very possible to buy from store a wrong spare because.....I don't now:banghead::-\.So can anyone post a scheme or a picture on how is looks like this gaskets???? Thanks guys. Hi Bella, I've just found your post. Check out this site: www.rockauto.com Pick the right vehicle type. When you get to the gaskets (keyword "Valve cover") there should be a button "More info" or something like this. Click on it and in the separate window you'll see the image of the gaskets. A week ago I bought a set for $11.00 + shipping. As far as I know they ship overseas too. I don't know if they accept Romanian currency. Good luck!!! Link to comment Share on other sites More sharing options...
