hmdavis Posted November 23, 2005 Share Posted November 23, 2005 small issue i noticed - my dashboard showed the "door open" signal so i went around and checked all the doors and noticed the rear hatch handle was 'sticking" so i sprayed it with wd40 and worked it back and forth a few times but it was still "sticking" so i manually moved it to the nuetral position for closing the door, the "door open" light on the dashboard went out. Fine - but today i noticed the metal plate around the handle is all rusted - is this normal? i would figure since the handle is protected by the overhang of the door this area would not see much in the way of water/moisture. all other areas of the door show no rust or rot. small issue but any comments? -easy to change other areas to watch? thanks, david Link to comment Share on other sites More sharing options...
fnlyfnd Posted November 23, 2005 Share Posted November 23, 2005 Mine is rusted very bad also. I remember reading somewhere that it is a common problem. Link to comment Share on other sites More sharing options...
nipper Posted November 23, 2005 Share Posted November 23, 2005 i have the same issue on my 97 nipper Link to comment Share on other sites More sharing options...
brus brother Posted November 24, 2005 Share Posted November 24, 2005 I replaced one on a 91 Legacy wagon. The part was about $15 from 1stSubaru parts.com. though I got a used one from a local board member. Pretty simple repair. Pop off the botom of the inside panel (I might have taken it off entirely), disconnect arm attached to handle. Remove two rusted bolts barely holding the handle and replace new handle and follow above in reverse order. Link to comment Share on other sites More sharing options...
gbhrps Posted November 24, 2005 Share Posted November 24, 2005 For several years that licence plate light/tailgate handle mounting bar was a problem for Subaru. I remember reading a thread where someone explained that it was the result of poor primer and paint, as well as the exhaust gases that are swept up around the tailgate when driving. I removed the one on my 97 OBW, blasted and repainted it. It wsn't a big job, just time consuming and fiddlely. Link to comment Share on other sites More sharing options...
teppichkopf Posted November 24, 2005 Share Posted November 24, 2005 You can thank the highway department for putting road salt down in the winter. I was looking at a 96 outback today and noticed that plate was comepletly rusted out I thought it was odd. Then when the carfax report showed the car lived it's first six years in Boston I knew why. Since in the northwest here road salt isn't used we usually don't have rust problems like this. Link to comment Share on other sites More sharing options...
nipper Posted November 24, 2005 Share Posted November 24, 2005 im afraid to take mine off .. its that far gone. i have a replacemnt coming in the mail from sopmone on the board. i can barely get mine to functionin the cold weather now. nipper Link to comment Share on other sites More sharing options...
stumpy Posted November 24, 2005 Share Posted November 24, 2005 Fixed one for a friend of mine. It was completly rusted off. $14.?? at the local Subaru dearler in Gresham for a new one. I have 4 Legacy's my self and only one of them work properly. The other three you have to manually return the handle to the neutral positon if you want it to close properly. Link to comment Share on other sites More sharing options...
Commuter Posted November 24, 2005 Share Posted November 24, 2005 http://www.ultimatesubaru.org/forum/showthread.php?t=2513&highlight=hatch+latch Find instructions herein. This was for a 97 OBW, but it should be pretty much the same. I've been spraying mine with Rust Check about twice a year since putting the new one on. No rust. Commuter Link to comment Share on other sites More sharing options...
Gnuman Posted November 24, 2005 Share Posted November 24, 2005 Mine has a bit of rust, just enough to make it stick just a bit every now and then. . I blasted it with penetrating oil, then put a few drops of regular lightweight machine oil where ie pivots, and all is well now. Link to comment Share on other sites More sharing options...
nipper Posted November 24, 2005 Share Posted November 24, 2005 I am actually shocked this peice is so cheap. I alos wonder if it something that the NHTSA admin needs to know about, as it can keep the rear hatch from closing securly. I wonder up to what year is affected by this. nipper Link to comment Share on other sites More sharing options...
nipper Posted November 26, 2005 Share Posted November 26, 2005 Ok i got a new handle, but the license plate light bracket that the handle go on are so rusted, i am afraid to try this repair without a replacement bracket. Any ideas on where i can get a new one? nipper Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 23, 2010 Share Posted June 23, 2010 my 95 has this issue too I have rust too it's pretty nasty good to know the price is still good Link to comment Share on other sites More sharing options...
bheinen74 Posted June 23, 2010 Share Posted June 23, 2010 teppichkopf said: You can thank the highway department for putting road salt down in the winter. I was looking at a 96 outback today and noticed that plate was comepletly rusted out I thought it was odd. Then when the carfax report showed the car lived it's first six years in Boston I knew why. Since in the northwest here road salt isn't used we usually don't have rust problems like this. +1 I have encountered 4 out of every 5 leg wagons in the junkyards that the handle is completely rusted off, so all you see is the little release cable end.......lots of broken out rear glass from people trying to get into the back to get the tailights off the cars......... This is a problem i would say doesnt affect west coasters too often Link to comment Share on other sites More sharing options...
Durania Posted June 23, 2010 Share Posted June 23, 2010 I noticed that on my 95 Outback yesterday. The whole area above the license plate is just about rusted through. Pretty random rusting place. Link to comment Share on other sites More sharing options...
nipper Posted June 23, 2010 Share Posted June 23, 2010 Durania said: I noticed that on my 95 Outback yesterday. The whole area above the license plate is just about rusted through. Pretty random rusting place. Not random. The aerodynamics on the rear of the captures all the road salt and it sits there. Link to comment Share on other sites More sharing options...
bheinen74 Posted June 24, 2010 Share Posted June 24, 2010 This should be stickied or something, this is something that each and everyone should be inspecting frequently, and inspecting fairly periodically. If this part rust and is no longer functional, one could become stranded if ever getting a flat tire, it would render getting to your spare impossible if the handle breaks due to rustage. Link to comment Share on other sites More sharing options...
nipper Posted June 24, 2010 Share Posted June 24, 2010 The parts to replace the entire assembly are under 30.oo so just easier to get the new parts Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 24, 2010 Share Posted June 24, 2010 Is it held in by screws on the inside? Link to comment Share on other sites More sharing options...
nipper Posted June 24, 2010 Share Posted June 24, 2010 yes Link to comment Share on other sites More sharing options...
murph Posted June 25, 2010 Share Posted June 25, 2010 96 legacy same thing , gonna go with a new one , closest Subaru dealer 1 hour away bummer . oh well , i love the car , so it's not a huge deal . all the best , murph Link to comment Share on other sites More sharing options...
