subynut Posted November 24, 2005 Share Posted November 24, 2005 Ok, I had two pistons that were toast, so I ordered a set from checker. BUT, they look different from the ones in the engine. I'm not sure they are the right ones. They're a BeckArnley 012-4968. Here's a pic: What gives? I talked to the guys at checker and he says that's the only set for both the ea-81 and ea82. Are they just a generic type of piston or what? I don't get it. Help? Link to comment Share on other sites More sharing options...
waimaks Posted November 24, 2005 Share Posted November 24, 2005 I'm no expert, but I'd be worried about not having the valve grooves in the top, and the longer skirt on teh bottom. Someone else on here will have a more definate answer though. Hope you kept your receipt cause Id be taking them back. Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted November 24, 2005 Share Posted November 24, 2005 Probably difference in turbo, carbureted, or SPFI Link to comment Share on other sites More sharing options...
Subarian Posted November 24, 2005 Share Posted November 24, 2005 THe one on the right looks like it's from a NA 1.8. The turbo pistons are dished to lower compression. Without the valve reliefs cut into the face of the piston, I think you'd be making your non-interference engine into an interference engine, if it ran at all. I don't think that's the right piston. Link to comment Share on other sites More sharing options...
subyrally Posted November 24, 2005 Share Posted November 24, 2005 the pins are smaller, the skirt is longer and there are no impressions for te valves. the longer skirts might make it less prone to piston slap. but thats about the only thing i see of any value with those pistons. personally, id get my money back and go with someone that works with these cars on a regualr basis. Link to comment Share on other sites More sharing options...
jacobs Posted November 24, 2005 Share Posted November 24, 2005 If you decide to use that new piston (I wouldn't), make sure it weighs exactly (to the gram) the same as your old one or else you could have a severe vibration. It appears to be a lot heavier than the old one. Also make sure the distance from the wrist pin to the top of the piston is the same. Link to comment Share on other sites More sharing options...
rol1 Posted November 24, 2005 Share Posted November 24, 2005 Looks like this is one of those times a factory piston from subaru, OR, get to pick-a-part and find a factory piston for $5. Link to comment Share on other sites More sharing options...
MudisFun Posted November 24, 2005 Share Posted November 24, 2005 Send them back!!! I got two ea82 pistons sitting right hear if you whant them. Link to comment Share on other sites More sharing options...
Mykeys Toy Posted November 24, 2005 Share Posted November 24, 2005 It is funny that they show the same part # for EA71 also. Link to comment Share on other sites More sharing options...
nipper Posted November 24, 2005 Share Posted November 24, 2005 send them back. There are simply too many differnces, and they are subtle differnces either. nipper Link to comment Share on other sites More sharing options...
ShawnW Posted November 24, 2005 Share Posted November 24, 2005 Ill trade you your two new checker ones for 4 of the ones you want, already clean and ready to install. Those look to be 1600 pistons which I need. I wont trade if yours are oversize pistons though. Link to comment Share on other sites More sharing options...
subynut Posted November 25, 2005 Author Share Posted November 25, 2005 Wow, looks like checker screwed up. Again. Why do I even bother going there? No wonder Napa didn't have them. Ok, I'll send them back. Since they are a full set, including rings. MudIsFun: Are those pistons off a SPFI engine? I'm also gonna call CCR and see what a new pair would be too. Thanks guys! Link to comment Share on other sites More sharing options...
MudisFun Posted November 26, 2005 Share Posted November 26, 2005 There from an ea82 SPFI, pay for shipping cost and buy me a WCSS 7 dvd, and they are yours! Link to comment Share on other sites More sharing options...
ccrinc Posted November 27, 2005 Share Posted November 27, 2005 THe new ones are either EA81 or EA71 pistons. Emily http://www.ccrengines.com Link to comment Share on other sites More sharing options...
subynut Posted November 28, 2005 Author Share Posted November 28, 2005 That's what I figured. Checker still doesn't believe me that they are the wrong ones. I pulled the pistons out of my brother's parts car, they're ok and they are SPFI too. So, I'm gonna use on of those. Thanks guys! Link to comment Share on other sites More sharing options...
