Extended steering shaft length.
singletrack
Hey Single This is Jerry, cut your shaft in half then get some tubing heavy wall that will fit over the shaft. Slide the tubing over 1 part of the shaft and install the parts on the car. Slide the tubing over the steering shafts and center the tubing. Spot weld it in place then remove it and weld it up and reinstall it. Done deal Thanks Jerry
