Indrid cold Posted November 26, 2005 Share Posted November 26, 2005 Hey, O.k, ready too split block. Chiltins says: (wrist pins are out, bolts loosened.) 9. Remove the cylinder block connecting bolts, except the one under the center journal: loosen the remaining bolt until it can be turned by hand. So the last bolt to come off is under the center journal....hmmmm... which bolt might that be.... and is it that important.... From this point is it a putty knife too slice in between and wrestle on floor? Any tricks or just take bolts out, roll so 1 & 3 cylanders are up and pull? Noob's. Link to comment Share on other sites More sharing options...
Indrid cold Posted November 26, 2005 Author Share Posted November 26, 2005 Pulled bolts, smacked a couple time with rubber hammer, came right apart. No problem.... Much ado about nothing. Link to comment Share on other sites More sharing options...
