Brat rear bed cover? What is it worth??
I payed $110.00 for mine brand new at the same time I bought mine 84 Brat brand new :D back in 1984
If you found one theres a rubber strip on the front edge of the tonnue that will run a long under the rear window and you should also get the track the the rubber will pinch into you will need to mount that just under the window
there is also velcro that needs to be mounted on the sides on the in side of the bed oppiste of the BRAT logo
the snaps go with the exsisting screws in the crome trim and new ones will be mounted in between them
theres also a suport rod that runs from side to side above the wheel well and below the crome strip on the inside of the bed
this prevents saging
does that help
Hassey
Just make sure that all the hard ware that i mention above come with the tonnue cover your looking at exspeaily the rail below the rear window you will diffenantly need that
the snaps you can pick up at an upolstery shop
