November 26, 200520 yr ...and as a layed it down on the scales... 2518 lbs!!!!!!!!!!!!!!!! I dont even have the light AL seats installed or the rest of the dyno matt taken out! Plus all the floor matts are in...rear cargo cover...and some of the other fluid tanks are full. But it is at near fuel starving level of fuel...meaning ~5 gallons left in it. hahaha... more to come as I empty those and take stuff out. Ok, done. Well, zeroed the scales again as it was showing -6 total when I was adjusting the collars... LF:753---RF:717 LR:527---RR:505 Total 2502 Cross--1245---49.7% Left---1280---51.1% Rear---1032---41.2% All weights are in US Pounds. Now...for a test drive...and experiement with swaybars vs no swaybars.
November 26, 200520 yr Author 2500 w/out rear cargo cover, all 4 floor matts...removed coin change and otherstuff floating around the car... 2496 after removing all the dynomat from behind the rear trim pannel. 7~10 lbs left to remove from under the rear carpet. Enough of that...cross weight is sitting at 51% right now...I'm off to make that 49.9~50.0% and call it a day. Oh...the two washer tanks are still mostly full...thats about another 6~10 lbs.
November 26, 200520 yr Author hahaha... last time I put it at 49.9%...then when I hope in, it goes to 50.0%. So with it at 49.7 and almost no gas...it'll be close enough for the time being. After all, new springs and shocks are comming soon...plus, only one autox left before the new season and its a non-points event anyhow. Plus I'll be running a new class. It'll weigh 2660 with me in it.
