johnceggleston Posted January 13, 2006 Share Posted January 13, 2006 what is the recommended oil for piston slap? will a thicker warm oil help...10/40? or a thicker cold oil 15/30 or 20/40? any one lost an engine after piston slap developed? lekmedm said: Well, here's the latest, and hopefully that last bit of news for this thread. I had the dealer go ahead and just do the HG replacement. It cost $1688 including machining the heads.As far as the knock is concerned.... yes, there's a knock. However, it seems to me that it is more of the piston-slap variety rather than bad bearings. It's worse when the engine is cold. It doesn't completely go away after fully hot, but it's not as noticeable. Oh, well. I think I might change over to Mobil 1. Maybe that'll help a bit. Thanks again for everyone's advice! Link to comment Share on other sites More sharing options...
Setright Posted January 14, 2006 Share Posted January 14, 2006 Piston slap is with most Subes on a cold start-up. Not terminal, but slightly annoying 'cause it sounds like a Diesel! I would suggest a 10W-40 oil as the best cure. Shell "Helix Plus", for example. M1 is a good oil, and the 5W-50 oil will be good to use, but it's relatively thin at low temps and will slap more than Helix. Link to comment Share on other sites More sharing options...
