beansy82 Posted November 27, 2005 Share Posted November 27, 2005 can u convert rear drum brakes to disk if you can do u just pull the drum off and put rotors on? Link to comment Share on other sites More sharing options...
NoahDL88 Posted November 27, 2005 Share Posted November 27, 2005 Disc Brake Conversion Link to comment Share on other sites More sharing options...
Subarian Posted November 27, 2005 Share Posted November 27, 2005 Noah, that's a very nice and clean article. I just picked up a turbo wagon for parts, and this is one of the items on my list. The only thing I would add to your article is the need to inspect and recondition or replace parts as necessary. I know it seems obvious to you and me, but not everyone who attempts the conversion will have a lot of experience with brakes. Thanks again for the excellent article. Link to comment Share on other sites More sharing options...
NoahDL88 Posted November 27, 2005 Share Posted November 27, 2005 Its not my article, its on the USRM, Obviously two things that are the most important are #1, make sure the pads and rotors are still in good condition, i'd reccomend new pads at the very least. and once you are done, bleed the brakes real good, any air bubbles in the system will make you not stop, funny story. #2, make sure the donor vehicle is the same as the recipient. 4wd to 4wd, or 2wd to 2wd. they don't swap over. Link to comment Share on other sites More sharing options...
Subarian Posted November 27, 2005 Share Posted November 27, 2005 Also check for ANY brake fluid on the outside of the caliper piston. If there's any there, you need to rebuild the caliper. Link to comment Share on other sites More sharing options...
