What will fit in my '79 4wd Wagon...
tjZ06
As the title says what can I swap into my '79 4wd Wagon. Emmisions and some custom fabrication are not a concern. But I don't want to be buying custom half-shafts, drive-shafts etc. I'm only looking for around 100hp so I'm not greedy. It'd be nice to bring a LSD and 5-speed along with the deal too. I, of course, want to retain 4wd. Thanks for any advice!
-TJ
you can swap in an ea81 easily enough. with a few mods to that engine (weber, cam, mild engine work) it can easily enough have 100 HP. Otherwise, an ea82T swap has been done. try a search, and that should give you a few ideas. Hope this jelps
  • 2 months later...
i never completed the swap. i did fit the engine into the engine bay but i never hooked up the trany.... lots of wiring and stuff and i sold the car to make room for a new project(one that i hope will be finished)
you could buy the adapter plate and mate the ej22 to a dr5speed, but you will have a very tight fit. some frame cutting will be needed. and lots of other extras.... if i were you i would fit an ea81.. my old wagon had one(1979) and it would do 80mph....
