rol1 Posted November 29, 2005 Share Posted November 29, 2005 So this has a 2wd so could I use this distributer with my 92 Loyale? As it suggest for N/A power tune-up? What HP does this mpfi xt4 ea82 have? Link to comment Share on other sites More sharing options...
calebz Posted November 29, 2005 Share Posted November 29, 2005 The NA MPFI has ~100 hp IIRC. However, the distributor should be the same as the loyale disty. Not real useful for a 'power tune' Link to comment Share on other sites More sharing options...
TROGDOR! Posted November 29, 2005 Share Posted November 29, 2005 The disty will not work. The XT takes the same one as the turbo models. The 2WD swap only applies to EA81 models, and all Loyales and XT's are EA82s. Link to comment Share on other sites More sharing options...
rol1 Posted November 30, 2005 Author Share Posted November 30, 2005 What can I do with the ea82 to get some more pep? TROGDOR! said: The disty will not work. The XT takes the same one as the turbo models. The 2WD swap only applies to EA81 models, and all Loyales and XT's are EA82s. Link to comment Share on other sites More sharing options...
DerFahrer Posted November 30, 2005 Share Posted November 30, 2005 The XT's had the highest HP rating of any NA EA82 at 97hp. The rest were 90. The disty on my XT NA is the knock-sensor equipped one, with full electronic advance. Link to comment Share on other sites More sharing options...
calebz Posted November 30, 2005 Share Posted November 30, 2005 TROGDOR! said: The disty will not work. The XT takes the same one as the turbo models. I used an SPFI disty in my Turbo Wagon. I can't imagin why he couldn't use asn MPFI disty in an SPFI car. 87+, all the SPFI/MPFI/Turbo EA82s use the same advance Link to comment Share on other sites More sharing options...
